[postgis-tickets] [PostGIS] #3131: KNN geography still gives ERROR: index returned tuples in wrong order
trac at osgeo.org
Fri May 29 15:38:07 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I'll take another backtrace after I'm done rebuilding postgres, but this
is what I have from weekold postgresql 9.5 after recent postgis install:
running this query -
SELECT gid, RANK() OVER(ORDER BY ST_Distance( 'POINT(95 10)'::geography,
geog) )
FROM knn_recheck_geog
ORDER BY 'POINT(95 10)'::geography <-> geog LIMIT 5;
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 12180.0x2e10]
0x00000000708a3324 in geography_distance_uncached
(fcinfo=fcinfo at entry=0x273e670) at geography_measurement.c:86
86 tolerance = PG_GETARG_FLOAT8(2);
(gdb) bt
#0 0x00000000708a3324 in geography_distance_uncached
#1 0x0000000000782ebf in DirectFunctionCall3Coll
(func=func at entry=0x708a3200 <geography_distance_uncached>,
collation=collation at entry=0, arg1=<optimized out>, arg2=<optimized out>,
arg3=arg3 at entry=0) at fmgr.c:1074
#2 0x00000000708a33f3 in geography_distance_knn (fcinfo=<optimized out>)
at geography_measurement.c:58
#3 0x000000000057c15b in ExecMakeFunctionResultNoSets (fcache=0x4b5e820,
econtext=0x4b5e0c0, isNull=0x4c380da "", isDone=<optimized out>) at
execQual.c:2018
#4 0x00000000005820c0 in ExecTargetList (isDone=0x273ebfc,
itemIsDone=0x4c38270, isnull=0x4c380d8 "", values=0x4c380a0,
econtext=0x4b5e0c0, targetlist=0x4c38210) at execQual.c:5363
#5 ExecProject (projInfo=<optimized out>, isDone=isDone at entry=0x273ebfc)
at execQual.c:5578
#6 0x000000000059eb33 in ExecWindowAgg
(winstate=winstate at entry=0x4b5dde8) at nodeWindowAgg.c:1746
#7 0x000000000057b0b8 in ExecProcNode (node=node at entry=0x4b5dde8) at
execProcnode.c:500
#8 0x0000000000598459 in ExecSort (node=node at entry=0x4b5db50) at
nodeSort.c:103
#9 0x000000000057b028 in ExecProcNode (node=node at entry=0x4b5db50) at
execProcnode.c:488
#10 0x0000000000590d90 in ExecLimit (node=node at entry=0x4b5d810) at
nodeLimit.c:91
#11 0x000000000057aed8 in ExecProcNode (node=node at entry=0x4b5d810) at
execProcnode.c:520
#12 0x0000000000577c7e in ExecutePlan (dest=0x4c30398,
direction=<optimized out>, numberTuples=0, sendTuples=1 '\001',
operation=CMD_SELECT, planstate=0x4b5d810, estate=0x4b5d6f8) at
execMain.c:1549
#13 standard_ExecutorRun (queryDesc=0x4b49728, direction=<optimized out>,
count=0) at execMain.c:337
#14 0x000000000068bd58 in PortalRunSelect (portal=portal at entry=0x4b51698,
forward=forward at entry=1 '\001', count=0, count at entry=41153104,
dest=dest at entry=0x0) at pquery.c:946
#15 0x000000000068d356 in PortalRun (portal=0x273eeb0,
portal at entry=0x4b51698, count=41153104, count at entry=2147483647,
isTopLevel=isTopLevel at entry=0 '\000', dest=0x0, dest at entry=0x4c30398,
altdest=altdest at entry=0x4c30398, compl
#16 0x000000000068ac54 in exec_simple_query (query_string=0x0) at
postgres.c:1104
#17 PostgresMain (argc=<optimized out>, argv=argv at entry=0x2a81a8,
dbname=0x10000f000e000d <error: Cannot access memory at address
0x10000f000e000d>, username=<optimized out>) at postgres.c:4025
#18 0x000000000062ac03 in BackendRun (port=0x273f400) at postmaster.c:4162
#19 SubPostmasterMain (argc=argc at entry=3, argv=argv at entry=0x317fa0) at
postmaster.c:4649
#20 0x00000000007c6b60 in main (argc=3, argv=0x317fa0) at main.c:198
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3131#comment:3>
