[postgis-tickets] [PostGIS] #3127: KNN geog distance doesn't match ST_Distance spheroid
PostGIS trac at osgeo.org
Sat May 30 18:41:00 PDT 2015
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Disregard my index comment -- not sure if its an issue of concern or not,
 but it seems the extra order by clause prevented use of spatial index so
 getting rid of the addtional order by a.gid seems to allow index to kick
 in.
 SELECT a.gid,  ARRAY(SELECT  (gid,a.geog <-> g.geog)
                         FROM knn_recheck_geog_small_2 As g WHERE a.gid <>
 g.gid ORDER BY a.geog <-> g.geog LIMIT 2) As knn ,
         ARRAY(SELECT  (gid, ST_Distance(a.geog, g.geog ) )
 g.gid ORDER BY ST_Distance(a.geog, g.geog) LIMIT 2) As dist
 FROM knn_recheck_geog_small_2 As a
 WHERE a.gid = 1000
 ORDER BY a.gid;
 but answer with index use is still the same with it thinking these two
 geometries are same distance. Seems like its still using sphere to me at
 r13589
 SELECT a.geog  <-> g.geog As knn_dist, ST_Distance(a.geog,g.geog) As dist,
 ST_Distance(a.geog,g.geog, false) As dist_sphere
 FROM (SELECT 'POINT(-105.45 3.8)'::geography) As a(geog) ,
     (VALUES ('POINT(-105.45 2.85)'::geography ) , ( 'POINT(-105.45
 4.75)'::geography) ) g(geog);
     knn_dist    |       dist       |  dist_sphere
  105635.3257479 | 105049.134514627 | 105635.3257479
  105635.3257479 | 105051.447591582 | 105635.3257479
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3127#comment:4>
