[postgis-tickets] [PostGIS] #3131: KNN geography still gives ERROR: index returned tuples in wrong order
trac at osgeo.org
Sun May 31 13:33:38 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
should be fixed at r13593 by reverting back to using sphere distance and
put a note in docs that its based on sphere distance. I still need to put
in a note in docs saying use ST_Distance for accurate measure, but that
will come with an example. Also have changed the tests to avoid using
rank in conjunction with index tests at r13594, I'm not sure why that
forces it not to use an index. Have to double check that one. That
doesn't make sense to me.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3131#comment:16>
