[postgis-tickets] [PostGIS] #3355: ST_Intersects() return no result with ST_Segmentize()
trac at osgeo.org
Sun Nov 1 20:38:14 PST 2015
Reporter: sdiz | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by sdiz):
The WKB is also the same, but "=" say 'f':
db=> WITH X AS
db-> ( SELECT 'LINESTRING(124.983539 1.419224,91.181596
29.647798)'::geography )
db-> SELECT
db-> (SELECT * from X),
db-> ST_Segmentize((SELECT * from X), 47487290),
db-> (SELECT * from X) = ST_Segmentize((SELECT * from X), 47487290);
-[ RECORD 1
geography |
0102000020E610000002000000CBD58F4DF23E5F40412C9B3924B5F63F6745D4449FCB56400A6AF816D6A53D40
st_segmentize |
?column? | f
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3355#comment:1>
