[postgis-tickets] [PostGIS] #3356: geometry to geography cast, always adds a box even for 2 point linestrings
trac at osgeo.org
Mon Nov 2 09:10:16 PST 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.1.x
Keywords: |
I noticed this when fixing #3355 that geometry to geography cast always
adds a bounding box. I had actually copied the solution from that
function to fix #3355. For ST_Segmentize it's probably a rare case you'll
segmentize and still end up with a 2 point linestring, but I can see this
as being more of an issue when casting between geometry /geography.
Observe:
SELECT ST_Summary(wkt::geometry) As wkt_geom,
ST_Summary(wkt::geography) As wkt_geog,
ST_Summary(wkt::geometry::geography) As geom_geog
FROM (SELECT
'LINESTRING(124.983539 1.419224,91.181596 29.647798)'::text As wkt)
As f;
outputs:
wkt_geom | wkt_geog |
geom_geog
LineString[] with 2 points | LineString[GS] with 2 points |
LineString[BGS] with 2 points
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3356>
