[postgis-tickets] [PostGIS] #3359: toTopoGeom misses a component linestring
PostGIS trac at osgeo.org
Sat Nov 7 00:44:03 PST 2015
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  high      |  Milestone:  PostGIS 2.2.1
Component:  topology  |    Version:  2.2.x
 Keywords:            |
 The attached script shows a bug in topology.toTopoGeom which fails to
 properly list 2 edges as components of a just-created TopoGeometry. It
 inserts a 3 vertices line first, creating an edge, and a 4 vertices line
 fully containing the first, creating a second edge. While
 TopoGeo_addLinestring properly returns both edges as being created, the
 relation table as populated by toTopoGeom contains a single edge for the
 newly added TopoGeometry record.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3359>
