[postgis-tickets] [PostGIS] #3359: toTopoGeom misses a component linestring
PostGIS trac at osgeo.org
Sat Nov 7 01:18:53 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 2.0.8
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 NOTE: this is not easy to reproduce because it only fails when both
 numbers in the second TopoElement (in this case {2,2}) are present in the
 array of already added elements, so it needs be done with an empty
 topology (so that first edge gets id=1 and second edge id=2)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3359#comment:4>
