[postgis-tickets] [PostGIS] #3367: ST_RemoveRepeatedPoints fails on empty inputs
PostGIS trac at osgeo.org
Sat Nov 14 16:41:49 PST 2015
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.2.1
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 nope still failing even after I delete the junk dumped in msys/local
 folder.
 /json-c/rel-0.12w32gcc481/lib -Le:/jenkins/CGAL/rel-
 sfcgal-1.2w32gcc481/lib
 /projects/proj/rel-4.9.1w32gcc481/lib/libproj.dll.a -lpthread
 /projects/json-c/rel-0.12w32gcc481/lib/libjson-c.a -lgeos_c
 /mingw/i686-w64-mingw32/lib/libcunit.a
 -L/sources/CUnit-2.1-2/CUnit/Sources e:/jenkins/CGAL/rel-
 sfcgal-1.2w32gcc481/lib/libSFCGAL.dll
 -L/projects/proj/rel-4.9.1w32gcc481/lib
 -L/projects/json-c/rel-0.12w32gcc481/lib -Le:/jenkins/CGAL/rel-
 Makefile:82: recipe for target `check' failed
 make[2]: *** [check] Error 53
 make[2]: Leaving directory
 `/projects/postgis/branches/2.2/liblwgeom/cunit'
 Makefile:186: recipe for target `check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom'
 GNUmakefile:16: recipe for target `check' failed
 make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3367#comment:3>
