[postgis-tickets] [PostGIS] #3369: winnie failing after remove points committ
PostGIS trac at osgeo.org
Sat Nov 14 17:31:40 PST 2015
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.2.1
 Component:  buildbots  |    Version:  2.2.x
Resolution:             |   Keywords:
Comment (by robe):
 okay turns out to be stupid me, no surprise there :)
 I had set it to use SFCGAL 1.2 branch, but the sfcgal-config generated by
 sfcgal generates this prefix:
 prefix=e:/jenkins/CGAL/rel-sfcgal-1.2w64gcc48
 which needs to be changed to
 prefix=/projects/CGAL/rel-sfcgal-1.2w64gcc48
 to work right.
 There was an SFCGAL change since last compile of PostGIS which triggers
 this issue.
 Anyrate, I have to put in logic in my sfcgal build to fix the generated
 sfcgal-config script.
 I'll close this out once I have that in place.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3369#comment:1>
