[postgis-tickets] r14384 - references #3369 revert accidental path change
Regina Obe lr at pcorp.us
Sun Nov 15 10:54:17 PST 2015
Author: robe
Date: 2015-11-15 10:54:17 -0800 (Sun, 15 Nov 2015)
New Revision: 14384
   buildbots/windows/mingw64/scripts/build_sfcgal.sh
Modified: buildbots/windows/mingw64/scripts/build_sfcgal.sh
--- buildbots/windows/mingw64/scripts/build_sfcgal.sh	2015-11-15 18:49:15 UTC (rev 14383)
+++ buildbots/windows/mingw64/scripts/build_sfcgal.sh	2015-11-15 18:54:17 UTC (rev 14384)
@@ -43,7 +43,7 @@
 rm -rf build${OS_BUILD}${GCC_TYPE}
 mkdir -p build${OS_BUILD}${GCC_TYPE}
 cd build${OS_BUILD}${GCC_TYPE}
-cmake -G "MSYS Makefiles" -DCMAKE_BUILD_TYPE:STRING=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE} -DBoost_USE_STATIC_LIBS=ON -DCMAKE_CXX_FLAGS:STRING="-DBOOST_THREAD_USE_LIB -DBoost_USE_STATIC_LIBS -DBOOST_USE_WINDOWS_H" -DBOOST_ROOT:PATH=${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE} ../SFCGAL-${SFCGAL_VER}
+cmake -G "MSYS Makefiles" -DCMAKE_BUILD_TYPE:STRING=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE} -DBoost_USE_STATIC_LIBS=ON -DCMAKE_CXX_FLAGS:STRING="-DBOOST_THREAD_USE_LIB -DBoost_USE_STATIC_LIBS -DBOOST_USE_WINDOWS_H" -DBOOST_ROOT:PATH=${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE} ${PROJECTS}/cgal/sfcgal/branches/${SFCGAL_VER}
 make
 make install
