[postgis-tickets] [PostGIS] #3361: gserialized_from_lwgeom takes is_geodetic arg but does nothing with it, geography_serialize may give you a geometry if not careful
trac at osgeo.org
Tue Nov 17 20:06:44 PST 2015
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
In going thru this exercise, I came across this function -
http://postgis.net/docs/doxygen/2.3/dc/d52/geography__measurement_8c_a7990577ab258de83502c7fb56ebfc202.html#a7990577ab258de83502c7fb56ebfc202
geography_point_outside
Which if I am not mistaken will end up returning a geometry (not a
geography), because of the bogusness of the gserialized_from_lwgeom
(since it's passing a geometry), presumably it will get a geometry back.
Do we use this function anywhere?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3361#comment:3>
