[postgis-tickets] [PostGIS] #3373: ALTER DOMAIN missing from topology_upgrade
PostGIS trac at osgeo.org
Sat Nov 21 00:21:18 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.2.1
 Component:  topology  |    Version:  2.2.x
Resolution:            |   Keywords:
Comment (by strk):
 I see ALTER lines are explicitly removed from the SQL file for the purpose
 of creating the upgrade script, but dont' understand why. Digging back in
 history I found r8157 being the commit that introduced the rule to create
 the upgrade script, by Regina in November 2011.
 Regina, where did you copy that from ? Why an ALTER is also condidered
 something that cannot be present in an upgrade ? The comment above that
 snippet says:
 +#Generate upgrade script by stripping things that can't be reinstalled
 +#e.g. don't bother with tables, types, triggers, and domains
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3373#comment:1>
