[postgis-tickets] [PostGIS] #3374: make installcheck should not run unit tests
trac at osgeo.org
Sat Nov 21 02:21:42 PST 2015
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: medium | Milestone: PostGIS Future
Component: build/upgrade/install | Version:
Keywords: |
There's no point in running unit tests on "make installcheck" as they
would still test the built, not the installed, code.
Only regression tests (run_test.pl) should be run by "make installcheck"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3374>
