[postgis-tickets] r14430 - #3375, repeated points crash
Paul Ramsey
pramsey at cleverelephant.ca
Wed Nov 25 13:45:50 PST 2015
Author: pramsey
Date: 2015-11-25 13:45:50 -0800 (Wed, 25 Nov 2015)
New Revision: 14430
branches/2.1/NEWS
branches/2.1/liblwgeom/lwgeom.c
branches/2.1/regress/tickets.sql
branches/2.1/regress/tickets_expected
Modified: branches/2.1/NEWS
--- branches/2.1/NEWS 2015-11-25 21:40:22 UTC (rev 14429)
+++ branches/2.1/NEWS 2015-11-25 21:45:50 UTC (rev 14430)
@@ -16,7 +16,9 @@
always return false as result.
- #3359, Fix toTopoGeom loss of low-id primitives from TopoGeometry
definition
+ - #3375, crash in repeated point removal for collection(point)
PostGIS 2.1.8
2015/07/07
Modified: branches/2.1/liblwgeom/lwgeom.c
--- branches/2.1/liblwgeom/lwgeom.c 2015-11-25 21:40:22 UTC (rev 14429)
+++ branches/2.1/liblwgeom/lwgeom.c 2015-11-25 21:45:50 UTC (rev 14430)
@@ -1341,6 +1341,11 @@
LWDEBUGF(4, "lwgeom_remove_repeated_points got type %s",
lwtype_name(in->type));
+ if(lwgeom_is_empty(in))
+ return lwgeom_clone_deep(in);
switch (in->type)
case MULTIPOINTTYPE:
@@ -1363,7 +1368,7 @@
case TRIANGLETYPE:
case TINTYPE:
/* No point is repeated for a single point, or for Triangle or TIN */
- return in;
case CIRCSTRINGTYPE:
case COMPOUNDTYPE:
@@ -1371,12 +1376,12 @@
case CURVEPOLYTYPE:
case MULTISURFACETYPE:
/* Dunno how to handle these, will return untouched */
- return in;
default:
lwnotice("lwgeom_remove_repeated_points: unsupported geometry type: %s",
- return in;
break;
return 0;
Modified: branches/2.1/regress/tickets.sql
--- branches/2.1/regress/tickets.sql 2015-11-25 21:40:22 UTC (rev 14429)
+++ branches/2.1/regress/tickets.sql 2015-11-25 21:45:50 UTC (rev 14430)
@@ -879,5 +879,9 @@
SELECT '#2788', valid, reason, ST_AsText(location) from ST_IsValidDetail('POLYGON((0 0, 0 1, 2 1, 2 2, 1 2, 1 0, 0 0))'::geometry);
SELECT '#2870', ST_Summary('Point(151.215289 -33.856885)'::geometry::bytea::geography);
+SELECT '#3367', ST_AsText(ST_RemoveRepeatedPoints('POLYGON EMPTY'::geometry));
+SELECT '#3375', ST_AsText(ST_RemoveRepeatedPoints('GEOMETRYCOLLECTION(POINT(1 1))'::geometry));
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: branches/2.1/regress/tickets_expected
--- branches/2.1/regress/tickets_expected 2015-11-25 21:40:22 UTC (rev 14429)
+++ branches/2.1/regress/tickets_expected 2015-11-25 21:45:50 UTC (rev 14430)
@@ -259,3 +259,5 @@
#2712|LINESTRING EMPTY
#2788|f|Self-intersection|POINT(1 1)
#2870|Point[GS]
+#3367|POLYGON EMPTY
+#3375|GEOMETRYCOLLECTION(POINT(1 1))
