[postgis-tickets] r14432 - Add topology.populate_topology_layer function
Sandro Santilli
strk at keybit.net
Wed Nov 25 15:22:15 PST 2015
Author: strk
Date: 2015-11-25 15:22:15 -0800 (Wed, 25 Nov 2015)
New Revision: 14432
trunk/NEWS
trunk/topology/topology.sql.in
Useful for passing data around.
Modified: trunk/NEWS
--- trunk/NEWS 2015-11-25 21:49:01 UTC (rev 14431)
+++ trunk/NEWS 2015-11-25 23:22:15 UTC (rev 14432)
@@ -5,7 +5,8 @@
* Deprecated signatures *
* New Features *
- - TopoGeom_addElement, TopoGeom_remElement (Sando Santilli)
+ - TopoGeom_addElement, TopoGeom_remElement (Sandro Santilli)
+ - populate_topology_layer (Sandro Santilli)
PostGIS 2.2.0
2015/10/07
Modified: trunk/topology/topology.sql.in
--- trunk/topology/topology.sql.in 2015-11-25 21:49:01 UTC (rev 14431)
+++ trunk/topology/topology.sql.in 2015-11-25 23:22:15 UTC (rev 14432)
@@ -812,7 +812,54 @@
--} DropTopoGeometryColumn
+-- populate_topology_layer
+-- Register missing layers into topology.topology, looking at
+-- their constraints.
+-- The function doesn't attempt to determine if a layer is
+-- hierarchical or primitive, but always assumes primitive.
+DROP FUNCTION IF EXISTS topology.populate_topology_layer();
+CREATE OR REPLACE FUNCTION topology.populate_topology_layer()
+ RETURNS TABLE(schema_name text, table_name text, feature_column text)
+AS
+ INSERT INTO topology.layer
+ WITH checks AS (
+ SELECT
+ n.nspname sch, r.relname tab,
+ replace(c.conname, 'check_topogeom_', '') col,
+ --c.consrc src,
+ regexp_matches(c.consrc,
+ '\.topology_id = (\d+).*\.layer_id = (\d+).*\.type = (\d+)') inf
+ FROM pg_constraint c, pg_class r, pg_namespace n
+ WHERE c.conname LIKE 'check_topogeom_%'
+ AND r.oid = c.conrelid
+ AND n.oid = r.relnamespace
+ ), newrows AS (
+ SELECT inf[1]::int as topology_id,
+ inf[2]::int as layer_id,
+ sch, tab, col, inf[3]::int as feature_type --, src
+ FROM checks c
+ WHERE NOT EXISTS (
+ SELECT * FROM topology.layer l
+ WHERE l.schema_name = c.sch
+ AND l.table_name = c.tab
+ AND l.feature_column = c.col
+ SELECT topology_id, layer_id, sch,
+ tab, col, feature_type,
+ 0, NULL
+ FROM newrows RETURNING schema_name,table_name,feature_column;
+LANGUAGE 'sql' VOLATILE;
-- CreateTopoGeom(topology_name, topogeom_type, layer_id, elements)
