[postgis-tickets] [PostGIS] #2294: shp2pgsql-gui exports all geometry columns but unselected column as text
trac at osgeo.org
Thu Nov 26 05:59:28 PST 2015
Reporter: robe | Owner: mcayland
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.9
Component: loader/dumper | Version: trunk
Resolution: wontfix | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => wontfix
Comment:
I think this is 'won't fix'. Obviously the second column isn't a geometry
column because shape can only have one geometry column at a time. And some
people will want second columns ignored and others won't, which implies
Yet More Configuration Flags, which is silly since it's such a minor case:
if you don't want the column, just ignore it, it's only going to be 256
bytes long at worst, the most DBF can handle.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2294#comment:4>
