[postgis-tickets] [PostGIS] #3379: Error during compilation of PostGIS source code
trac at osgeo.org
Thu Nov 26 07:20:47 PST 2015
Reporter: bleukert | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.1
Component: build/upgrade/install | Version: 2.2.x
Keywords: |
During the compilation of the PostGIS source code (exported from svn-2.2
branch) I received the following error message:
gcc -O2 -Wall -Wmissing-prototypes -I/opt/libgeos/include
-I/opt/libproj/include -I/opt/cunit/include -I.. -c -o cu_out_twkb.o
cu_out_twkb.c[[BR]]
cu_out_twkb.c:1: error: stray ‘\357’ in program[[BR]]
cu_out_twkb.c:1: error: stray ‘\273’ in program[[BR]]
cu_out_twkb.c:1: error: stray ‘\277’ in program[[BR]]
make[2]: *** [cu_out_twkb.o] Error 1[[BR]]
make[2]: Leaving directory `/tmp/postgis/postgis-
svn-2.2/liblwgeom/cunit'[[BR]]
make[1]: *** [check] Error 2[[BR]]
make[1]: Leaving directory `/tmp/postgis/postgis-svn-2.2/liblwgeom'[[BR]]
make: *** [check] Error 1
Can you please fix the file cu_out_twkb.c?
Best regards,[[BR]]
Boris
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3379>
