[postgis-tickets] [PostGIS] #3381: Can't load postgis - 'unknown error 193'
trac at osgeo.org
Fri Nov 27 11:49:19 PST 2015
Reporter: kylotan | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Keywords: |
I get this dialog in PGAdmin (and the text at the end if I just try the
SQL statement 'create extension postgis')
pgAdmin III
An error has occurred:
ERROR: could not load library "C:/Program
Files/PostgreSQL/9.4/lib/postgis-2.2.dll": unknown error 193
I've confirmed that I'm running 64 bit versions of everything, and that
there's no other instance of postgis-2.2.dll on my hard disk.
OS: Win 8.1. 64bit
Postgres: PostgreSQL 9.4.5, compiled by Visual C++ build 1800, 64-bit
postgis: 2.2.0 64bit, downloaded from
http://download.osgeo.org/postgis/windows/pg94/archive/ or installed via
StackBuilder from EnterpriseDB, makes no difference
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3381>
