[postgis-tickets] [PostGIS] #3381: Can't load postgis - 'unknown error 193'
trac at osgeo.org
Fri Nov 27 18:34:04 PST 2015
Reporter: kylotan | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords: windows
Comment (by robe):
Just to confirm - you were using this one right?
http://download.osgeo.org/postgis/windows/pg94/postgis-bundle-
pg94x64-setup-2.2.0-1.exe
When you install via Stackbuilder -- it shows two, if you chose the 32-bit
one time then it shows that error. If one time
I just checked one of the installs I did via stackbuilder and it shows
this but that's a windows 2012 R2 (which should be pretty similar to
windows 8 and 8.1)
POSTGIS="2.2.0 r14208" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1, 04
March 2015" GDAL="GDAL 2.0.1, released 2015/09/15" LIBXML="2.7.8"
LIBJSON="0.12" RASTER
So I think the binaries are okay.
Now if you did make a mistake once and copied the 32-bit libraries or
installed the 32-bit install and reinstall the 64-bit postgis. Your
install might still be broken.
This is because the libxml2-2.dll doesn't get overwritten (that's because
sometimes EDB distributes that and sometimes they don't so the installer
installs one if it doesn't see one present, and if you just copied from
the zip, you would get that one).
So if that is the issue, what you could do is delete the libxml2-2.dll and
copy the one called libxml2.dll (and give the new copy name libxml2-2.dll
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3381#comment:2>
