[postgis-tickets] [PostGIS] #3381: Can't load postgis - 'unknown error 193'
trac at osgeo.org
Sat Nov 28 08:09:00 PST 2015
Reporter: kylotan | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.2.1
Component: build/upgrade/install | Version: 2.2.x
Resolution: worksforme | Keywords: windows
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
Great so not an issue with the installer. What a relief. Though I still
would like to prevent such a thing from happening at least not to show
both the 32-bit and 64-bit if you picked the PostgreSQL 64-bit port
install. I asked EDB folks about this a while back they said technically
since a 32-bit software can be installed on a 64-bit OS, the way the
application builder works, it has to show both as options. So people who
are only on 32-bit only ever see the 32-bit option (but sadly 64-bit
people see both regardless which version of PostgreSQL they picked). :)
For future I may minimize this by just always overwriting the
libxml2-2.dll for 64-bit install. As I recall, I think it might only be
for the 32-bit where they sometimes package libxml2-2.dll and sometimes
they don't. The main reason I don't overwrite is if they do have a
liblxml2-2.dll, means they are linking with that name and their libxml
version has more stuff compiled in than what I bother with including with
PostGIS, so PostGIS will work with their version, but their version may
not work with what I ship.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3381#comment:5>
