[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
PostGIS trac at osgeo.org
Tue Sep 1 14:49:48 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 finally got it - I think I just had to compile with enable-debug on.
 this is what I get for the mingw postgres (which returns the wrong answer)
 DEBUG:  [lwgeom_accum.c:pgis_geometry_accum_transfn:125] Number of args 3
 DEBUG:  [lwgeom_accum.c:pgis_geometry_accum_transfn:134] Datum value
 4.02286e-316
 This is for the vc++ postgresql (which returns the right answer)
 2.47697e-316
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3220#comment:18>
