[postgis-tickets] [PostGIS] #3280: Almost collinear edges prevent adding a copy of existing edge
trac at osgeo.org
Fri Sep 18 05:19:35 PDT 2015
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: topology | Version: 2.0.x
Resolution: | Keywords:
Comment (by strk):
Note that adding the 3-vertices line _before_ the 2-vertices line results
in a different topology which does not prevent adding the 2-vertices line
again.
State of topology after adding straight line first:
[[Image(testbug-error.png)]]
State of topology after adding straight line second:
[[Image(testbug-noerror.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3280#comment:1>
