[postgis-tickets] [PostGIS] #3301: PostGIS_HasBBOX regress with 2.1.8 (intentional change?)
trac at osgeo.org
Tue Sep 29 12:26:03 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
I suspect this is intentional, but logging it as a regress just in case.
Testing with
POSTGIS="2.2.0dev r14136" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.9.1,
04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15" LIBXML="2.7.8"
LIBJSON="0.12" (core procs from "2.2.0dev r14092" need upgrade) RASTER
(raster procs from "2.2.0dev r14092" need upgrade)
SELECt PostGIS_HasBBox('LINESTRING(-11 70,70 -10)'::geometry)
In 2.1.8 this returns true, but in 2.2.0 returns false.
Returns true for 3 point, so I am guessing this is just an optimization
change since the box talkes as much sapce a the geometry.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3301>
