[postgis-tickets] [PostGIS] #1946: 'Spatial exception - geometry intersects edge 5' exception at adding 3 polygons
trac at osgeo.org
Wed Sep 30 07:12:59 PDT 2015
polygons
Reporter: wimned | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.7
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by strk):
This seems to work with current trunk version (to become 2.2.0 as of
r14155) but now with the tip of the 2.1 branch (to become 2.1.9 as of
r14154). Can you confirm ?
I hadn't tried to figure out what changed between the two versions.
The summary of the topology built with 2.2.0dev is:
Topology wimpy (id 2626, SRID 4326, precision 1e-05)+
6 nodes, 9 edges, 4 faces, 0 topogeoms in 0 layers +
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1946#comment:6>
