[postgis-tickets] [PostGIS] #3518: PostgreSQL 9.5.2 windows (EDB) incompatible with PostGIS 2.2.2 binaries
PostGIS trac at osgeo.org
Fri Apr 1 18:15:17 PDT 2016
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 2.2.3
Component:  build/upgrade/install  |    Version:  2.2.x
 Keywords:  windows                |
 As noted here, while the binaries we have for PostGIS 2.2 work fine with
 PostgresQL 9.5.1 windows 64-bit, they fail when loading raster
 when using PostgreSQL 9.5.2
 https://lists.osgeo.org/pipermail/postgis-users/2016-April/041315.html
 I think someone also complained about 9.4.  I'm suspecting the update they
 did to libeasy32.dll, ssleasy32.dll they did is the culprit since its
 failing with
 ERROR:  could not load library rtpostgis-2.2.dll: The specified procedure
 could not be found.
 and raster relies on GDAL which relies on Curl which relies on
 ssleasy32.dll and libeasy32.dll for https support.  I don't distribute
 these 2 libraries but compiled with versions compatible before so I could
 use the ones EDB packages.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3518>
