[postgis-tickets] [PostGIS] #3519: El Capitan - CREATE EXTENSION postgis fails with "ERROR: could not load library "/Library/PostgreSQL/9.5/lib/postgresql/rtpostgis-2.2.so": dlopen(/Library/PostgreSQL/9.5/lib/postgresql/rtpostgis-2.2.so, 10): Symbol not found: _SSLv2_client_method"
PostGIS trac at osgeo.org
Wed Apr 6 00:26:59 PDT 2016
  Reporter:  remy     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS PostgreSQL
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:  _SSLv2_client_method
Changes (by robe):
 * owner:  pramsey => robe
 * milestone:  PostGIS 2.2.3 => PostGIS PostgreSQL
Comment:
 This sounds like the same issue I ran into and fixed on windows.
 Unfortunately I don't package for MacOSX so you need to talk with EDB
 folks directly and have them rebuild their GDAL library.
 The issue I ran into on windows and fixed detailed here -
 http://www.postgresonline.com/journal/archives/364-PostGIS-2.2-Windows-
 users-hold-off-on-installing-latest-PostgreSQL-patch-release.html
 In older versions they compiled with a lower SSL and in 9.5.2 (at least
 for windows they upgraded the OpenSSL library to a version that is
 incompatible with what they shipped in 9.5.1 - assume the same case on
 Mac) .  So Short answer - the libcurl they are shipping (to support GDAL)
 needs to be compiled with newer version of SSL.
 I'll relay your message to them.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3519#comment:1>
