[postgis-tickets] [PostGIS] #3519: El Capitan - CREATE EXTENSION postgis fails with "ERROR: could not load library "/Library/PostgreSQL/9.5/lib/postgresql/rtpostgis-2.2.so": dlopen(/Library/PostgreSQL/9.5/lib/postgresql/rtpostgis-2.2.so, 10): Symbol not found: _SSLv2_client_method"
trac at osgeo.org
Fri Apr 8 04:14:31 PDT 2016
Reporter: remy | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 2.2.x
Resolution: fixed | Keywords: _SSLv2_client_method
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Note from EDB folks about MacOSX packages:
New updates with the fix are available through StackBuilder.
Please give those a try should fix this issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3519#comment:3>
