[postgis-tickets] [PostGIS] #3524: Getting distance between united States and Russia in geography hangs up the server
PostGIS trac at osgeo.org
Sat Apr 9 09:03:06 PDT 2016
server
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.1.9
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> My server seems pretty frozen computing these and it's still trying to
> compute the distance between these two countries and it's been 15 minutes
> already.
> After about 17 minutes or waiting I decided to just cancel the query and
> the query would not cancel even after 7 minutes of waiting.  Then I tried
> to pg_terminate_backend it, and that still did not work.  So I had to
> finally end up killing my service entirely.
> I know they are big but really?  I should at least be able to cancel.
> We were testing on 2.2.1, but decided to also test on 2.1.8 (postgresql
> 9.4).  Same issue on both.
> Us has 36054 points and Russia has 36352
> Query is as follows:
> SELECT ST_Distance(a.geog, b.geog)
> FROM   (SELECT geom::geography As geog, ST_NPoints(geom) As npoints FROM
> ur_test WHERE name = 'United States') AS a
> ,  (SELECT geom::geography AS geog, ST_NPoints(geom) As npoints FROM
> ur_test WHERE name = 'Russia') AS b
> Casting to geography is quick.  Doing distance on geometry I think was
> about 2 seconds.
New description:
 already.
 After about 17 minutes of waiting I decided to just cancel the query and
 about 2 seconds.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3524#comment:1>
