[postgis-tickets] r14827 - #1851, correct to_wgs parameters for epsg:3844
Paul Ramsey
pramsey at cleverelephant.ca
Mon Apr 11 11:25:46 PDT 2016
Author: pramsey
Date: 2016-04-11 11:25:46 -0700 (Mon, 11 Apr 2016)
New Revision: 14827
branches/2.0/spatial_ref_sys.sql
Modified: branches/2.0/spatial_ref_sys.sql
--- branches/2.0/spatial_ref_sys.sql 2016-04-10 05:20:52 UTC (rev 14826)
+++ branches/2.0/spatial_ref_sys.sql 2016-04-11 18:25:46 UTC (rev 14827)
@@ -9106,7 +9106,7 @@
--- EPSG 3844 : Pulkovo 1942(58) / Stereo70
-INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (3844,'EPSG',3844,'PROJCS["Pulkovo 1942(58) / Stereo70",GEOGCS["Pulkovo 1942(58)",DATUM["Pulkovo_1942_58",SPHEROID["Krassowsky 1940",6378245,298.3,AUTHORITY["EPSG","7024"]],TOWGS84[2.329,-147.042,-92.08,0.309,-0.325,-0.497,5.69],AUTHORITY["EPSG","6179"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4179"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Oblique_Stereographic"],PARAMETER["latitude_of_origin",46],PARAMETER["central_meridian",25],PARAMETER["scale_factor",0.99975],PARAMETER["false_easting",500000],PARAMETER["false_northing",500000],AUTHORITY["EPSG","3844"],AXIS["X",NORTH],AXIS["Y",EAST]]','+proj=sterea +lat_0=46 +lon_0=25 +k=0.99975 +x_0=500000 +y_0=500000 +ellps=krass +towgs84=2.329,-147.042,-92.08,0.309,-0.325,-0.497,5.69 +units=m +no_defs ');
+INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (3844,'EPSG',3844,'PROJCS["Pulkovo 1942(58) / Stereo70",GEOGCS["Pulkovo 1942(58)",DATUM["Pulkovo_1942_58",SPHEROID["Krassowsky 1940",6378245,298.3,AUTHORITY["EPSG","7024"]],TOWGS84[2.3287,-147.0425,-92.0802,-0.3092483,0.32482185,0.49729934,5.68906266],AUTHORITY["EPSG","6179"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4179"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Oblique_Stereographic"],PARAMETER["latitude_of_origin",46],PARAMETER["central_meridian",25],PARAMETER["scale_factor",0.99975],PARAMETER["false_easting",500000],PARAMETER["false_northing",500000],AUTHORITY["EPSG","3844"],AXIS["X",NORTH],AXIS["Y",EAST]]','+proj=sterea +lat_0=46 +lon_0=25 +k=0.99975 +x_0=500000 +y_0=500000 +ellps=krass +towgs84=2.3287,-147.0425,-92.0802,-0.3092483,0.32482185,0.49729934,5.68906266 +units=m +no_defs ');
--- EPSG 3845 : SWEREF99 / RT90 7.5 gon V emulation
