[postgis-tickets] [PostGIS] #3524: ST_Distance for geography should be cancellable
trac at osgeo.org
Mon Apr 11 12:23:53 PDT 2016
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by pramsey):
So, "yes" to interruptible, I'll do that right away. It's easy to see why
it takes forever: with the first, uncached call happening in the "brute
force" algorithm, you get 36K x 36K edge-edge distance calculations, which
is... a lot 1.2B. So it takes a while. Running the tree-based calculation,
I get a result in a under a second (and that's with four calculations!):
postgis23=# select _st_distancetree(a.geog, b.geog) from ur_test_g a,
ur_test_g b;
_st_distancetree
0
3987.916904757
3987.916904757
0
(4 rows)
Time: 801.691 ms
So that maybe argues for forgoing the brute force calculation altogether
and just using the tree every time. (Although we have other tickets that
still show failure cases in the tree, compared to the brute force, in
terms of correct results.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3524#comment:5>
