[postgis-tickets] r14836 - Fix reference to ST_LineLocatePoint
Sandro Santilli strk at keybit.net
Wed Apr 13 01:52:02 PDT 2016
Author: strk
Date: 2016-04-13 01:52:02 -0700 (Wed, 13 Apr 2016)
New Revision: 14836
   trunk/doc/po/ja/reference_lrs.xml.po
Should fix #3527
Modified: trunk/doc/po/ja/reference_lrs.xml.po
--- trunk/doc/po/ja/reference_lrs.xml.po	2016-04-12 21:39:32 UTC (rev 14835)
+++ trunk/doc/po/ja/reference_lrs.xml.po	2016-04-13 08:52:02 UTC (rev 14836)
@@ -1,5 +1,5 @@
 # SOME DESCRIPTIVE TITLE.
 # Translators:
 # TERAMOTO Ikuhiro <yellow at affrc.go.jp>, 2016
 msgid ""
@@ -70,7 +70,7 @@
 msgid ""
 "See <xref linkend=\"ST_LineLocatePoint\"/> for computing the line location "
 "nearest to a Point."
-msgstr "ポイントに最も近いライン位置の計算については<xref linkend=\"ST_Line_Locate_Point\"/>を参照して下さい。"
+msgstr "ポイントに最も近いライン位置の計算については<xref linkend=\"ST_LineLocatePoint\"/>を参照して下さい。"
 #. Tag: para
 #: reference_lrs.xml:34
