[postgis-tickets] [PostGIS] #3529: ST_Subdivide test should only be activated when available
PostGIS trac at osgeo.org
Wed Apr 13 09:11:29 PDT 2016
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.2.3
 Component:  postgis  |    Version:  2.2.x
Resolution:  fixed    |   Keywords:
Comment (by strk):
 Should you put that test in the subdivide.sql/subdivide_expect files,
 already only running when dependencies are met ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3529#comment:2>
