[postgis-tickets] [PostGIS] #3513: topology tests failing for PostgreSQL 9.6
PostGIS trac at osgeo.org
Wed Apr 27 07:27:16 PDT 2016
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  reopened
  Priority:  blocker   |  Milestone:  PostGIS 2.3.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 still failing - he is the diff I get locally after svn update
 --- regress/gml_expected        2015-07-30 14:50:43 -0400
 +++ /projects/postgis/tmp/2.3_pg9.6w64/test_43_out      2016-04-27
 10:20:02 -0400
 @@ -51,12 +51,13 @@
  P2-customprefix|<cstm:TopoSurface><cstm:directedFace><cstm:Face
 cstm:id="F4"><cstm:directedEdge orientation="-"><cstm:Edge
 cstm:id="E7"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N17"/></cstm:directedNode><cstm:directedNode><cstm:Node
 cstm:id="N18"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsName="urn:ogc:def:crs:EPSG::4326"><cstm:segments><cstm:LineStringSegment><cstm:posList
 srsDimension="2">21 22 35
 22</cstm:posList></cstm:LineStringSegment></cstm:segments></cstm:Curve></cstm:curveProperty></cstm:Edge></cstm:directedEdge><cstm:directedEdge><cstm:Edge
 cstm:id="E17"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N13"/></cstm:directedNode><cstm:directedNode><cstm:Node
 srsDimension="2">35 14 35
 orientation="-"><cstm:Edge cstm:id="E10"><cstm:directedNode
 cstm:id="N14"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">35 14 21
 14</cstm:posList></cstm:LineStringSegment></cstm:segments></cstm:Curve></cstm:curveProperty></cstm:Edge></cstm:directedEdge><cstm:directedEdge
 orientation="-"><cstm:Edge cstm:id="E19"><cstm:directedNode
 cstm:id="N14"/></cstm:directedNode><cstm:directedNode><cstm:Node
 cstm:id="N17"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">21 14 21
 22</cstm:posList></cstm:LineStringSegment></cstm:segments></cstm:Curve></cstm:curveProperty></cstm:Edge></cstm:directedEdge></cstm:Face></cstm:directedFace><cstm:directedFace><cstm:Face
 cstm:id="F7"><cstm:directedEdge><cstm:Edge
 cstm:id="E10"><cstm:directedNode orientation="-"><cstm:Node
 14</cstm:posList></cstm:LineStringSegment></cstm:segments></cstm:Curve></cstm:curveProperty></cstm:Edge></cstm:directedEdge><cstm:directedEdge><cstm:Edge
 cstm:id="E18"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N10"/></cstm:directedNode><cstm:directedNode><cstm:Node
 cstm:id="N13"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">35 6 35
 cstm:id="E13"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N9"/></cstm:directedNode><cstm:directedNode><cstm:Node
 cstm:id="N10"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">21 6 35
 6</cstm:posList></cstm:LineStringSegment></cstm:segments></cstm:Curve></cstm:curveProperty></cstm:Edge></cstm:directedEdge><cstm:directedEdge
 orientation="-"><cstm:Edge cstm:id="E20"><cstm:directedNode
 srsDimension="2">21 6 21
 14</cstm:posList></cstm:LineStringSegment></cstm:segments></cstm:Curve></cstm:curveProperty></cstm:Edge></cstm:directedEdge></cstm:Face></cstm:directedFace></cstm:TopoSurface>
  P3-customprefix|<cstm:TopoSurface><cstm:directedFace><cstm:Face
 cstm:id="F5"><cstm:directedEdge orientation="-"><cstm:Edge
 cstm:id="E8"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N18"/></cstm:directedNode><cstm:directedNode><cstm:Node
 cstm:id="N19"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">35 22 47
 cstm:id="E15"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N12"/></cstm:directedNode><cstm:directedNode><cstm:Node
 srsDimension="2">47 14 47
 cstm:id="E11"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N12"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">35 14 47
 orientation="-"><cstm:Edge cstm:id="E17"><cstm:directedNode
 cstm:id="F8"><cstm:directedEdge orientation="-"><cstm:Edge
 cstm:id="E16"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N11"/></cstm:directedNode><cstm:directedNode><cstm:Node
 srsDimension="2">47 6 47
 cstm:id="E14"><cstm:directedNode orientation="-"><cstm:Node
 cstm:id="N11"/></cstm:directedNode><cstm:curveProperty><cstm:Curve
 srsDimension="2">35 6 47
 orientation="-"><cstm:Edge cstm:id="E18"><cstm:directedNode
  R2-visited|<TopoCurve><directedEdge><Edge id="E4"><directedNode
 orientation="-"><Node id="N5"/></directedNode><directedNode><Node
 id="N6"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>36 38 38 35 41
 34 42 33 45 32 47 28 50 28 52 32 57
 33</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
 orientation="-"><Edge id="E5"><directedNode orientation="-"><Node
 id="N7"/></directedNode><directedNode xlink:href="#N6"
 /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>41 40 45 40 47
 42 62 41 61 38 59 39 57 36 57
 33</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
 +ERROR:  syntax error at or near "ORDER" at character 1
  S1-visited|<TopoPoint><directedNode><Node id="N14"><pointProperty><Point
 srsName="EPSG:4326"><pos>21
 14</pos></Point></pointProperty></Node></directedNode></TopoPoint>
  S3-visited|<TopoPoint><directedNode xlink:href="#N6" /></TopoPoint>
  R1-visited|<TopoCurve><directedEdge><Edge id="E9"><directedNode
 orientation="-"><Node id="N15"/></directedNode><directedNode
 xlink:href="#N14" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 21
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
 orientation="-"><Edge id="E10"><directedNode orientation="-"><Node
 id="N13"/></directedNode><directedNode xlink:href="#N14"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 21
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
  N1N6N14-visited|<TopoPoint><directedNode><Node
 id="N1"><pointProperty><Point srsName="EPSG:4326"><pos>8
 30</pos></Point></pointProperty></Node></directedNode><directedNode
 xlink:href="#N6" /><directedNode xlink:href="#N14" /></TopoPoint>
 -P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge
 orientation="-"><Edge id="E7"><directedNode orientation="-"
 xlink:href="#N17" /><directedNode><Node
 id="N18"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 22 35
 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge
 id="E17"><directedNode orientation="-" xlink:href="#N13" /><directedNode
 xlink:href="#N18" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 35
 orientation="-" xlink:href="#E10" /><directedEdge orientation="-"
 xlink:href="#E19" /></Face></directedFace><directedFace><Face
 id="F7"><directedEdge xlink:href="#E10" /><directedEdge><Edge
 id="E18"><directedNode orientation="-"><Node
 id="N10"/></directedNode><directedNode xlink:href="#N13"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 35
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge
 id="E13"><directedNode orientation="-" xlink:href="#N9" /><directedNode
 xlink:href="#N10" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 35
 6</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
 orientation="-" xlink:href="#E20" /></Face></directedFace></TopoSurface>
 -P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge
 orientation="-"><Edge id="E6"><directedNode orientation="-"><Node
 id="N16"/></directedNode><directedNode><Node
 id="N17"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 22 21
 id="E19"><directedNode orientation="-" xlink:href="#N14" /><directedNode
 xlink:href="#N17" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 14 21
 xlink:href="#E9" /><directedEdge orientation="-"><Edge
 id="E21"><directedNode orientation="-" xlink:href="#N15" /><directedNode
 xlink:href="#N16" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 9
 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></Face></directedFace><directedFace><Face
 id="F6"><directedEdge orientation="-" xlink:href="#E9"
 /><directedEdge><Edge id="E20"><directedNode orientation="-"><Node
 id="N9"/></directedNode><directedNode xlink:href="#N14"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 21
 id="E12"><directedNode orientation="-"><Node
 id="N8"/></directedNode><directedNode xlink:href="#N9"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 21
 orientation="-"><Edge id="E22"><directedNode orientation="-"
 xlink:href="#N8" /><directedNode xlink:href="#N15" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 9
 14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></Face></directedFace></TopoSurface>
 +P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge
 orientation="-"><Edge id="E7"><directedNode orientation="-"><Node
 id="N17"/></directedNode><directedNode><Node
 orientation="-" xlink:href="#E10" /><directedEdge orientation="-"><Edge
 id="E13"><directedNode orientation="-"><Node
 id="N9"/></directedNode><directedNode xlink:href="#N10"
 orientation="-"><Edge id="E20"><directedNode orientation="-"
 xlink:href="#N9" /><directedNode xlink:href="#N14" /><curveProperty><Curve
 +P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge
 id="N16"/></directedNode><directedNode xlink:href="#N17"
 xlink:href="#E19" /><directedEdge xlink:href="#E9" /><directedEdge
 orientation="-"><Edge id="E21"><directedNode orientation="-"
 xlink:href="#N15" /><directedNode xlink:href="#N16"
 id="F6"><directedEdge orientation="-" xlink:href="#E9" /><directedEdge
 xlink:href="#E20" /><directedEdge><Edge id="E12"><directedNode
 orientation="-"><Node id="N8"/></directedNode><directedNode
 xlink:href="#N9" /><curveProperty><Curve
  F3F4-visited|<TopoSurface><directedFace xlink:href="#F3" /><directedFace
 xlink:href="#F4" /></TopoSurface>
  E7E8-visited|<TopoCurve><directedEdge xlink:href="#E7"
 /><directedEdge><Edge id="E8"><directedNode orientation="-"
 xlink:href="#N18" /><directedNode><Node
 id="N19"/></directedNode><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 22 47
 22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
  P3-visited-idprefix|<TopoSurface><directedFace><Face
 id="cd-F5"><directedEdge orientation="-" xlink:href="#cd-E8"
 /><directedEdge><Edge id="cd-E15"><directedNode orientation="-"><Node
 id="cd-N12"/></directedNode><directedNode xlink:href="#cd-N19"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>47 14 47
 id="cd-E11"><directedNode orientation="-" xlink:href="#cd-N13"
 /><directedNode xlink:href="#cd-N12" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 47
 orientation="-" xlink:href="#cd-E17"
 /></Face></directedFace><directedFace><Face id="cd-F8"><directedEdge
 orientation="-" xlink:href="#cd-E11" /><directedEdge><Edge
 id="cd-E16"><directedNode orientation="-"><Node
 id="cd-N11"/></directedNode><directedNode xlink:href="#cd-N12"
 srsName="EPSG:4326"><segments><LineStringSegment><posList>47 6 47
 id="cd-E14"><directedNode orientation="-" xlink:href="#cd-N10"
 /><directedNode xlink:href="#cd-N11" /><curveProperty><Curve
 srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 47
 orientation="-" xlink:href="#cd-E18"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3513#comment:4>
