[postgis-tickets] r14870 - Some syle consistency (and drop trailing whitespaces)
Sandro Santilli
strk at keybit.net
Thu Apr 28 02:37:36 PDT 2016
Author: strk
Date: 2016-04-28 02:37:36 -0700 (Thu, 28 Apr 2016)
New Revision: 14870
trunk/NEWS
Modified: trunk/NEWS
--- trunk/NEWS 2016-04-27 14:45:28 UTC (rev 14869)
+++ trunk/NEWS 2016-04-28 09:37:36 UTC (rev 14870)
@@ -2,24 +2,27 @@
2015/XX/XX
* Important / Breaking Changes *
- #3466, Casting from box3d to geometry now returns a 3D
- geometry (Julien Rouhaud)
+ geometry (Julien Rouhaud)
* Deprecated signatures *
* New Features *
- #3391, Add table inheritance support in ST_EstimatedExtent
- (Alessandro Pasotti)
+ (Alessandro Pasotti)
- TopoGeom_addElement, TopoGeom_remElement (Sandro Santilli)
- populate_topology_layer (Sandro Santilli)
- - #2259 ST_Voronoi (Dan Baston)
- - #2991 Enable ST_Transform to use PROJ.4 text (Mike Toews)
- - #3339 ST_GeneratePoints (Paul Ramsey)
- - #3362 ST_ClusterDBSCAN (Dan Baston)
- - #3364 ST_GeometricMedian (Dan Baston)
- - #3424 ST_MinimumClearance (Dan Baston)
- - #3428 ST_Points (Dan Baston)
- - #3465 ST_ClusterKMeans (Paul Ramsey)
- - #3469 ST_MakeLine with MULTIPOINTs (Paul Norman)
+ - #2259, ST_Voronoi (Dan Baston)
+ - #2991, Enable ST_Transform to use PROJ.4 text (Mike Toews)
+ - #3339, ST_GeneratePoints (Paul Ramsey)
+ - #3362, ST_ClusterDBSCAN (Dan Baston)
+ - #3364, ST_GeometricMedian (Dan Baston)
+ - #3424, ST_MinimumClearance (Dan Baston)
+ - #3428, ST_Points (Dan Baston)
+ - #3465, ST_ClusterKMeans (Paul Ramsey)
+ - #3469, ST_MakeLine with MULTIPOINTs (Paul Norman)
PostGIS 2.2.2
2016/03/22
@@ -34,7 +37,7 @@
- #3435, ST_AsX3D fix rendering of concave geometries
- #3436, memory handling mistake in ptarray_clone_deep
- #3437, ST_Intersects incorrect for MultiPoints
- - #3461, ST_GeomFromKML crashes Postgres when there are
+ - #3461, ST_GeomFromKML crashes Postgres when there are
innerBoundaryIs and no outerBoundaryIs
- #3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms
- #3460, ST_ClusterWithin 'Tolerance not defined' error after upgrade
@@ -55,7 +58,7 @@
- #3349, Fix installation path of postgis_topology scripts
- #3351, set endnodes isolation on ST_RemoveIsoEdge
(and lwt_RemIsoEdge)
- - #3355, geography ST_Segmentize has geometry bbox
+ - #3355, geography ST_Segmentize has geometry bbox
- #3359, Fix toTopoGeom loss of low-id primitives from
TopoGeometry definition
- #3360, _raster_constraint_info_scale invalid input syntax
@@ -92,15 +95,15 @@
- #2565, ST_SummaryStats(tablename, rastercolumn, ...) uses
ST_SummaryStatsAgg()
- #2567, ST_Count(tablename, rastercolumn, ...) uses ST_CountAgg()
- - #2842, raster - Hide unselectable tables from raster_overview
+ - #2842, raster - Hide unselectable tables from raster_overview
and raster_columns
- By default, PostGIS raster disables all GDAL drivers affecting
out-db rasters, ST_FromGDALRaster() and ST_AsGDALRaster() variants
- #3181, POINT EMPTY is now stored as POINT(NaN NaN) in WKB, instead of as MULTIPOINT EMPTY
- Java binding moved to separate repository:
https://github.com/postgis/postgis-java
- #2748, ST_Shift_Longitude renamed to ST_ShiftLongitude,
@@ -164,7 +167,7 @@
rasters with out-db bands
- #2387, address_standardizer extension as part of PostGIS
Stephen Woodbridge (imaptools.com), Walter Sinclair, Regina Obe
- - #2816, address_standardizer_data_us extension
+ - #2816, address_standardizer_data_us extension
provides reference lex,gaz,rules for address_standardizer
- #2341, New mask parameter for ST_MapAlgebra
@@ -255,7 +258,7 @@
band indexes
- #3088, Do not (re)define strcasestr in a liblwgeom.h
- #3094, Malformed GeoJSON inputs crash backend
PostGIS 2.1.6
2015/03/20
@@ -311,7 +314,7 @@
* Bug Fixes *
- - #2605, armel: _ST_Covers() returns true for point in hole
+ - #2605, armel: _ST_Covers() returns true for point in hole
- #2911, Fix output scale on ST_Rescale/ST_Resample/ST_Resize of rasters
with scale 1/-1 and offset 0/0.
- Fix crash in ST_Union(raster)
@@ -327,7 +330,7 @@
- #2784, Fix handling of bogus argument to --with-sfcgal
- #2772, Premature memory free in RASTER_getBandPath (ST_BandPath)
- #2755, Fix regressions tests against all versions of SFCGAL
- - #2775, lwline_from_lwmpoint leaks memory
+ - #2775, lwline_from_lwmpoint leaks memory
- #2802, ST_MapAlgebra checks for valid callback function return value
- #2803, ST_MapAlgebra handles no userarg and STRICT callback function
- #2834, ST_Estimated_Extent and mixedCase table names (regression bug)
@@ -336,10 +339,10 @@
- #2872, make install builds documentation (Greg Troxell)
- #2819, find isfinite or replacement on Centos5 / Solaris
- #2899, geocode limit 1 not returning best answer (tiger geocoder)
- - #2903, Unable to compile on FreeBSD
+ - #2903, Unable to compile on FreeBSD
- #2927 reverse_geocode not filling in direction prefix (tiger geocoder)
- get rid of deprecated ST_Line_Locate_Point called
+ get rid of deprecated ST_Line_Locate_Point called
PostGIS 2.1.3
2014/05/13
@@ -368,7 +371,7 @@
- #2534, st_distance returning incorrect results for large geographies
- #2539, Check for json-c/json.h presence/usability before json/json.h
- #2543, invalid join selectivity error from simple query
- - #2546, GeoJSON with string coordinates parses incorrectly
+ - #2546, GeoJSON with string coordinates parses incorrectly
- #2547, Fix ST_Simplify(TopoGeometry) for hierarchical topogeoms
- #2552, Fix NULL raster handling in ST_AsPNG, ST_AsTIFF and
ST_AsJPEG
@@ -387,7 +390,7 @@
- #2655, Let users without topology privileges call postgis_full_version()
- #2674, Fix missing operator = and hash_raster_ops opclass on raster
- #2675, #2534, #2636, #2634, #2638, Geography distance issues with tree optimization
* Enhancements *
- #2494, avoid memcopy in GiST index (hayamiz)
@@ -398,7 +401,7 @@
* Important Changes *
- - #2514, Change raster license from GPL v3+ to v2+, allowing
+ - #2514, Change raster license from GPL v3+ to v2+, allowing
distribution of PostGIS Extension as GPLv2.
* Bug Fixes *
@@ -411,7 +414,7 @@
- #2489, Fix upgrades from 2.0 leaving stale function signatures
- #2493, Fix behavior of ST_DumpValues when passed an empty raster
- #2502, Fix postgis_topology_scripts_installed() install schema
- - #2504, Fix segfault on bogus pgsql2shp call
+ - #2504, Fix segfault on bogus pgsql2shp call
- #2512, Support for foreign tables and materialized views in
raster_columns and raster_overviews
- #2525, Fix handling of SRID in nested collections
@@ -425,7 +428,7 @@
- #2478, support for tiger 2013
- #2527, Added -k flag to raster2pgsql to skip checking that
band is NODATA
PostGIS 2.1.0
2013/08/17
@@ -433,9 +436,9 @@
- #1653, Removed srid parameter from ST_Resample(raster) and variants
with reference raster no longer apply reference raster's SRID.
- - #1962 ST_Segmentize - As a result of
+ - #1962 ST_Segmentize - As a result of
the introduction of geography support, The construct:
- SELECT ST_Segmentize('LINESTRING(1 2, 3 4)',0.5);
+ SELECT ST_Segmentize('LINESTRING(1 2, 3 4)',0.5);
will result in ambiguous function error
- #2026, ST_Union(raster) now unions all bands of all rasters
- #2089, liblwgeom: lwgeom_set_handlers replaces lwgeom_init_allocators.
@@ -475,8 +478,8 @@
- #310, ST_DumpPoints converted to a C function (Nathan Wagner)
- #739, UpdateRasterSRID()
- - #945, improved join selectivity, N-D selectivity calculations,
- user accessible selectivity and stats reader functions for
+ - #945, improved join selectivity, N-D selectivity calculations,
+ user accessible selectivity and stats reader functions for
testing (Paul Ramsey / OpenGeo)
- toTopoGeom with TopoGeometry sink (Sandro Santilli / Vizzuality)
- clearTopoGeom (Sandro Santilli / Vizzuality)
@@ -494,7 +497,7 @@
in one call (Bborie Park / UC Davis)
- #1293, ST_Resize(raster) to resize rasters based upon width/height
- #1627, package tiger_geocoder as a PostgreSQL extension
- - #1643, #2076, Upgrade tiger geocoder to support loading tiger 2011 and 2012
+ - #1643, #2076, Upgrade tiger geocoder to support loading tiger 2011 and 2012
(Regina Obe / Paragon Corporation) Funded by Hunter Systems Group
- GEOMETRYCOLLECTION support for ST_MakeValid (Sandro Santilli / Vizzuality)
- #1709, ST_NotSameAlignmentReason(raster, raster)
@@ -509,9 +512,9 @@
- #1895, new r-tree node splitting algorithm (Alex Korotkov)
- #2011, ST_DumpValues to output raster as array (Bborie Park / UC Davis)
- #2018, ST_Distance support for CircularString, CurvePolygon, MultiCurve,
- MultiSurface, CompoundCurve
+ MultiSurface, CompoundCurve
- #2030, n-raster (and n-band) ST_MapAlgebra (Bborie Park / UC Davis)
- - #2193, Utilize PAGC parser as drop in replacement for tiger normalizer
+ - #2193, Utilize PAGC parser as drop in replacement for tiger normalizer
(Steve Woodbridge, Regina Obe)
- #2210, ST_MinConvexHull(raster)
- lwgeom_from_geojson in liblwgeom (Sandro Santilli / Vizzuality)
@@ -525,10 +528,10 @@
- #2164, ST_TRI for raster (Nathaniel Clay)
- #2302, ST_Roughness for raster (Nathaniel Clay)
- #2290, ST_ColorMap(raster) to generate RGBA bands
- - #2254, Add SFCGAL backend support.
+ - #2254, Add SFCGAL backend support.
(Backend selection throught postgis.backend var)
- Functions available both throught GEOS or SFCGAL:
- ST_Intersects, ST_3DIntersects, ST_Intersection, ST_Area,
+ Functions available both throught GEOS or SFCGAL:
+ ST_Intersects, ST_3DIntersects, ST_Intersection, ST_Area,
ST_Distance, ST_3DDistance
New functions available only with SFCGAL backend:
ST_3DIntersection, ST_Tesselate, ST_3DArea, ST_Extrude, ST_ForceLHR
@@ -539,7 +542,7 @@
* Enhancements *
- - #823, tiger geocoder: Make loader_generate_script download portion
+ - #823, tiger geocoder: Make loader_generate_script download portion
less greedy
- #826, raster2pgsql no longer defaults to padding tiles. Flag -P
can be used to pad tiles
@@ -551,12 +554,12 @@
- #1780, support ST_GeoHash for geography
- #1796, Big performance boost for distance calculations in geography
- #1802, improved function interruptibility.
- - #1823, add parameter in ST_AsGML to use id column for GML 3 output
+ - #1823, add parameter in ST_AsGML to use id column for GML 3 output
(become mandatory since GML 3.2.1)
- - #1856, tiger geocoder: reverse geocoder rating setting for prefer
+ - #1856, tiger geocoder: reverse geocoder rating setting for prefer
numbered highway name
- #1938, Refactor basic ST_AddBand to add multiple new bands in one call
- - #1978, wrong answer when calculating length of a closed circular
+ - #1978, wrong answer when calculating length of a closed circular
arc (circle)
- #1989, Preprocess input geometry to just intersection with raster
to be clipped
@@ -578,10 +581,10 @@
- #2149, Addition of spatially_unique constraint for raster
- TopologySummary output now includes unregistered layers and a count
of missing TopoGeometry objects from their natural layer.
- - ST_HillShade(), ST_Aspect() and ST_Slope() have one new optional
+ - ST_HillShade(), ST_Aspect() and ST_Slope() have one new optional
parameter to interpolate NODATA pixels before running the
operation.
- - Point variant of ST_SetValue(raster) is now a wrapper around geomval
+ - Point variant of ST_SetValue(raster) is now a wrapper around geomval
variant of ST_SetValues(rast).
- Proper support for raster band's isnodata flag in core API and loader.
- Additional default values for parameters of ST_Aspect and ST_HillShade
@@ -607,14 +610,14 @@
when count is zero
- #1932, fix raster2pgsql of syntax for index tablespaces
- #1936, ST_GeomFromGML on CurvePolygon causes server crash
- - #1939, remove custom data types: summarystats, histogram, quantile,
+ - #1939, remove custom data types: summarystats, histogram, quantile,
valuecount
- #1951, remove crash on zero-length linestrings
- - #1957, ST_Distance to a one-point LineString returns NULL
+ - #1957, ST_Distance to a one-point LineString returns NULL
- #1976, Geography point-in-ring code overhauled for more reliability
- #1981, cleanup of unused variables causing warnings with gcc 4.6+
- #1996, support POINT EMPTY in GeoJSON output
- - #2062, improve performance of distance calculations
+ - #2062, improve performance of distance calculations
- #2057, Fixed linking issue for raster2psql to libpq
- #2077, Fixed incorrect values returning from ST_Hillshade()
- #2019, ST_FlipCoordinates does not update bbox
@@ -670,13 +673,13 @@
* Bug Fixes *
- #2494, avoid memcpy in GIST index
- #2528, Fix memory leak in ST_Split / lwline_split_by_line
- #2532, Add missing raster/geometry commutator operators
- #2533, Remove duplicated signatures
@@ -684,7 +687,7 @@
- #2555, Fix parsing issue of range arguments of ST_Reclass
- #2589, Remove use of unnecessary void pointers
- #2607, Cannot open more than 1024 out-db files in process
- - #2610, Ensure face splitting algorithm uses the edge index
+ - #2610, Ensure face splitting algorithm uses the edge index
- #2619, Empty ring array in GeoJSON polygon causes crash
- #2638, Geography distance on M geometries sometimes wrong
@@ -739,12 +742,12 @@
- #1391, Errors during upgrade from 1.5
- #1828, Poor selectivity estimate on ST_DWithin
- #1838, error importing tiger/line data
- - #1869, ST_AsBinary is not unique -
+ - #1869, ST_AsBinary is not unique -
added to legacy_minor/legacy.sql scripts
- #1885, Missing field from tabblock table in tiger2010 census_loader.sql
- #1891, Use LDFLAGS environment when building liblwgeom
- #1899, Enhance toTopoGeom error on unsupported input
- - #1900, Fix pgsql2shp for big-endian systems
+ - #1900, Fix pgsql2shp for big-endian systems
- #1932, Fix raster2pgsql for invalid syntax for setting index tablespace
- #1955, ST_ModEdgeHeal and ST_NewEdgeHeal for doubly connected edges
@@ -752,7 +755,7 @@
- #1978, wrong answer calculating length of closed circular arc (circle)
- #1981, Remove unused but set variables as found with gcc 4.6+
- - #1987, Restore 1.5.x behaviour of ST_Simplify
+ - #1987, Restore 1.5.x behaviour of ST_Simplify
to be clipped
- #1991, geocode really slow on PostgreSQL 9.2
@@ -762,9 +765,9 @@
contain an arc
- #2015, ST_IsEmpty('POLYGON(EMPTY)') returns False
- - #2025, Fix side location conflict at TopoGeo_AddLineString
+ - #2025, Fix side location conflict at TopoGeo_AddLineString
- - #2033, Fix adding a splitting point into a 2.5d topology
+ - #2033, Fix adding a splitting point into a 2.5d topology
- #2051, Fix excess of precision in ST_AsGeoJSON output
- #2052, Fix buffer overflow in lwgeom_to_geojson
- #2056, Fixed lack of SRID check of raster and geometry in ST_SetValue()
@@ -772,33 +775,33 @@
- #2060, Fix "dimension" check violation by GetTopoGeomElementArray
- #2072, Removed outdated checks preventing ST_Intersects(raster) from
working on out-db bands
- - #2077, Fixed incorrect answers from ST_Hillshade(raster)
+ - #2077, Fixed incorrect answers from ST_Hillshade(raster)
- #2092, Namespace issue with ST_GeomFromKML,ST_GeomFromGML for libxml 2.8+
- - #2099, Fix double free on exception in ST_OffsetCurve
+ - #2099, Fix double free on exception in ST_OffsetCurve
- #2100, ST_AsRaster() may not return raster with specified pixel type
- #2108, Ensure ST_Line_Interpolate_Point always returns POINT
- #2109, Ensure ST_Centroid always returns POINT
- #2117, Ensure ST_PointOnSurface always returns POINT
- #2129, Fix SRID in ST_Homogenize output with collection input
- - #2130, Fix memory error in MultiPolygon GeoJson parsing
+ - #2130, Fix memory error in MultiPolygon GeoJson parsing
- Update URL of Maven jar
* Enhancements *
- #1581, ST_Clip(raster, ...) no longer imposes NODATA on a band if the
corresponding band from the source raster did not have NODATA
- #1928, Accept array properties in GML input multi-geom input
(Kashif Rasul and Shoaib Burq / SpacialDB)
- #2082, Add indices on start_node and end_node of topology edge tables
- - #2087, Speedup topology.GetRingEdges using a recursive CTE
+ - #2087, Speedup topology.GetRingEdges using a recursive CTE
PostGIS 2.0.1
2012/06/22
* Bug Fixes *
- - #1264, fix st_dwithin(geog, geog, 0).
+ - #1264, fix st_dwithin(geog, geog, 0).
- #1468 shp2pgsql-gui table column schema get shifted
- #1694, fix building with clang. (vince)
- #1708, improve restore of pre-PostGIS 2.0 backups.
@@ -818,19 +821,19 @@
- #1791, fix ST_Azimuth with very close but distinct points.
- #1797, fix (ValidateTopology(xxx)).* syntax calls.
- #1805, put back the 900913 SRID entry.
- - #1813, Only show readable relations in metadata tables.
+ - #1813, Only show readable relations in metadata tables.
- #1819, fix floating point issues with ST_World2RasterCoord and
ST_Raster2WorldCoord variants.
- #1820 compilation on 9.2beta1.
- #1822, topology load on PostgreSQL 9.2beta1.
- #1825, fix prepared geometry cache lookup
- #1829, fix uninitialized read in GeoJSON parser
- - #1834, revise postgis extension to only backup
+ - #1834, revise postgis extension to only backup
user specified spatial_ref_sys
- #1839, handling of subdatasets in GeoTIFF in raster2pgsql.
- #1840, fix logic of when to compute # of tiles in raster2pgsql.
- #1851, fix spatial_ref_system parameters for EPSG:3844
- - #1857, fix failure to detect endpoint mismatch in ST_AddEdge*Face*
+ - #1857, fix failure to detect endpoint mismatch in ST_AddEdge*Face*
- #1865, data loss in postgis_restore.pl when data rows have leading
dashes.
- #1867, catch invalid topology name passed to topogeo_add*
@@ -840,21 +843,21 @@
on-the-line case
- #1875, ST_SummaryStats returns NULL for all parameters except count
when count is zero
- - #1881, shp2pgsql-gui -- editing a field sometimes triggers
+ - #1881, shp2pgsql-gui -- editing a field sometimes triggers
removing row
- - #1883, Geocoder install fails trying to run
+ - #1883, Geocoder install fails trying to run
create_census_base_tables() (Brian Panulla)
* Enhancements *
- More detailed exception message from topology editing functions.
- - #1786, improved build dependencies
+ - #1786, improved build dependencies
- #1806, speedup of ST_BuildArea, ST_MakeValid and ST_GetFaceGeometry.
- #1812, Add lwgeom_normalize in LIBLWGEOM for more stable testing.
PostGIS 2.0.0
2012/04/03
- Upgrading to PostGIS 2.0 REQUIRES a dump and restore. See the
@@ -869,20 +872,20 @@
(eg CREATE TABLE t (g GEOMETRY(Polgyon, 4326)))
- ST_AsBinary and ST_AsText now return 3D/4D results in ISO SQL/MM
format when called on 3D/4D features.
- - The "unknonwn SRID" is now 0, not -1.
+ - The "unknonwn SRID" is now 0, not -1.
(eg ST_SRID(ST_GeomFromText('POINT(0 0)')) returns 0)
- - ST_NumGeometries returns 1 for singletons. ST_GeometryN returns the
+ - ST_NumGeometries returns 1 for singletons. ST_GeometryN returns the
the geometry for singletons.
- probe_geometry_columns(), rename_geometry_table_constraints(),
fix_geometry_columns(), have been removed since GEOMETRY_COLUMNS
is now a view.
- - 3D analysis functions are now named with "3D" as a prefix
+ - 3D analysis functions are now named with "3D" as a prefix
instead of a suffix (eg ST_Length3D has become ST_3DLength)
- Operator && does not check for SRID mismatch anymore
* New Features *
- - KNN Gist index based centroid (<->) and box (<#>) distance
+ - KNN Gist index based centroid (<->) and box (<#>) distance
operators (Paul Ramsey / funded by Vizzuality)
- PostgreSQL 9.1+ "extension" support (Regina Obe)
- Typmod support for geometry (Paul Ramsey)
@@ -893,11 +896,11 @@
(Company developer and funding: University Laval, Deimos Space, CadCorp,
Michigan Tech Research Institute, Paragon Corporation, Azavea)
- N-Dimensional spatial indexes (Paul Ramsey / OpenGeo)
- - Topology support improved, documented, testing, bug fixes
+ - Topology support improved, documented, testing, bug fixes
(Sandro Santilli / Faunalia for RT-SIGTA, Regina Obe, Andrea Peri,
Jose Carlos Martinez Llari)
- 3D relationship support functions (Nicklas Avén)
- ST_3DDistance, ST_3DClosestPoint, ST_3DIntersects,
+ ST_3DDistance, ST_3DClosestPoint, ST_3DIntersects,
ST_3DShortestLine
- ST_Split (Sandro Santilli / Faunalia for RT-SIGTA)
- ST_Node (Sandro Santilli)
@@ -923,36 +926,36 @@
- Made loader tolerant of truncated multibyte values found
in some free worldwide shapefiles (Sandro Santilli)
- Lots of bug fixes and enhancements to shp2pgsql
- Beefing up regression tests for loaders
+ Beefing up regression tests for loaders
Reproject support for both geometry and geography during import
(Jeff Adams / Azavea, Mark Cave-Ayland)
- - pgsql2shp conversion from predefined list
- (Loic Dachary / Mark Cave-Ayland)
- - Shp-pgsql GUI - support loading multiple files. (Mark Leslie)
- - Shp-pgsql GUI - support exporting multiple tablee. (Mark Cave-Ayland)
- - Extras - upgraded tiger_geocoder from using old TIGER format
+ - pgsql2shp conversion from predefined list
+ (Loic Dachary / Mark Cave-Ayland)
+ - Shp-pgsql GUI - support loading multiple files. (Mark Leslie)
+ - Shp-pgsql GUI - support exporting multiple tablee. (Mark Cave-Ayland)
+ - Extras - upgraded tiger_geocoder from using old TIGER format
to use new TIGER shp and file structure format (Stephen Frost)
- Enhancements and documentation of TIGER geocoder
- (Regina Obe, Leo Hsu / Paragon Corporation /
+ (Regina Obe, Leo Hsu / Paragon Corporation /
funding provided by Hunter Systems Group)
- Documentation proofreading and corrections. (Kasif Rasul)
* All Fixes and Enhancements *
- http://trac.osgeo.org/postgis/query?status=closed&milestone=PostGIS+2.0.0
* Acknowledgements *
- We are most indebted to the numerous members in the PostGIS community
- who were brave enough to TEST out the new features in this release.
- No major release can be successful without lots of testing.
+ We are most indebted to the numerous members in the PostGIS community
+ who were brave enough to TEST out the new features in this release.
+ No major release can be successful without lots of testing.
Below is an incomplete list of some of the many folks who helped
us get to this release.
- Andrea Peri - Lots of testing on topology, checking for correctness
- Andreas Forø Tollefsen - raster testing
- Chris English - topology stress testing loader functions
- - Salvatore Larosa - Lots of topology testing
+ - Salvatore Larosa - Lots of topology testing
- Brian Hamlin - Benchmarking, general testing all components
- Mike Pease - Tiger geocoder testing, very detailed reports of issues
- Tom van Tilburg - raster testing
@@ -967,9 +970,9 @@
- Bug Fixes
- #1056, produce correct bboxes for arc geometries, fixes index errors
(Paul Ramsey)
- - #1007, ST_IsValid crash - fix requires GEOS 3.3.0+ or 3.2.3+
+ - #1007, ST_IsValid crash - fix requires GEOS 3.3.0+ or 3.2.3+
(Sandro Santilli, reported by Birgit Laggner)
- - #940, support for PostgreSQL 9.1 beta 1
+ - #940, support for PostgreSQL 9.1 beta 1
(Regina Obe, Paul Ramsey, patch submitted by stl)
- #845, ST_Intersects precision error (Sandro Santilli, Nicklas Avén)
Reported by cdestigter
@@ -980,10 +983,10 @@
- #630, Peculiar Null treatment in arrays in ST_Collect (Chris Hodgson)
Reported by David Bitner
- #624, Memory leak in ST_GeogFromText (ryang, Paul Ramsey)
- - #609, Bad source code in manual section 5.2 Java Clients
+ - #609, Bad source code in manual section 5.2 Java Clients
(simoc, Regina Obe)
- #604, shp2pgsql usage touchups (Mike Toews, Paul Ramsey)
- - #573 ST_Union fails on a group of linestrings
+ - #573 ST_Union fails on a group of linestrings
Not a PostGIS bug, fixed in GEOS 3.3.0
- #457 ST_CollectionExtract returns non-requested type
(Nicklas Avén, Paul Ramsey)
@@ -994,7 +997,7 @@
Reported by Sdikiy
- #373 Documentation syntax error in hard upgrade (Paul Ramsey)
Reported by psvensso
PostGIS 1.5.2
2010/09/27
@@ -1008,8 +1011,8 @@
Geometry ST_Equals not using spatial index (Regina Obe, Nicklas Avén)
- #573, Improvement to ST_Contains geography
- Loader: Add support for command-q shutdown in Mac GTK build (Paul Ramsey)
- - #393, Loader: Add temporary patch for large DBF files
- (Maxime Guillaud, Paul Ramsey)
+ - #393, Loader: Add temporary patch for large DBF files
+ (Maxime Guillaud, Paul Ramsey)
- #507, Fix wrong OGC URN in GeoJSON and GML output (Olivier Courtin)
- spatial_ref_sys.sql Add datum conversion for projection SRID 3021
(Paul Ramsey)
@@ -1021,26 +1024,26 @@
- #562, ST_Dwithin errors for large geographies (Paul Ramsey)
- #513, shape loading GUI tries to make spatial index when loading DBF only
mode (Paul Ramsey)
- - #527, shape loading GUI should always append log messages
+ - #527, shape loading GUI should always append log messages
(Mark Cave-Ayland)
- #504 shp2pgsql should rename xmin/xmax fields (Sandro Santilli)
- - #458 postgis_comments being installed in contrib instead of
+ - #458 postgis_comments being installed in contrib instead of
version folder (Mark Cave-Ayland)
- #474 Analyzing a table with geography column crashes server
(Paul Ramsey)
- #581 LWGEOM-expand produces inconsistent results
(Mark Cave-Ayland)
- #471 DocBook dtd errors (Olivier Courtin)
- - Fix further build issues against PostgreSQL 9.0
+ - Fix further build issues against PostgreSQL 9.0
(Mark Cave-Ayland)
- - #572 Password whitespace for Shape File to PostGIS
+ - #572 Password whitespace for Shape File to PostGIS
Import not supported (Mark Cave-Ayland)
- #603: shp2pgsql: "-w" produces invalid WKT for MULTI* objects.
(Mark Cave-Ayland)
- Enhancement
- #513 Add dbf filter to shp2pgsql-gui and allow uploading dbf only
(Paul Ramsey)
PostGIS 1.5.1
2010/03/11
@@ -1063,12 +1066,12 @@
(Olivier Courtin)
- #443, incorrect coordinate reversal in GML 3 generation
(Olivier Courtin)
- - #450, #451, wrong area calculation for geography features that
+ - #450, #451, wrong area calculation for geography features that
cross the date line
(Paul Ramsey)
- Ensure support for upcoming 9.0 PgSQL release
(Paul Ramsey)
PostGIS 1.5.0
2010/02/04
@@ -1076,17 +1079,17 @@
- =~ operator now indicates bounding box equality, not feature equality
- GEOS 3.1 is now the minimum accepted version of GEOS
- - GEOS 3.2 is needed if you want to use enhanced buffering features
+ - GEOS 3.2 is needed if you want to use enhanced buffering features
and ST_HausdorffDistance
- GEOS, LibXML2, and Proj4 are now mandatory dependencies
* New Features *
- Added Hausdorff distance calculations (#209) (Vincent Picavet)
- - Added parameters argument to ST_Buffer operation to support one-sided
+ - Added parameters argument to ST_Buffer operation to support one-sided
buffering and other buffering styles (Sandro Santilli)
- Performance improvements to ST_Distance (Nicklas Avén)
- - Addition of other Distance related visualization and analysis
+ - Addition of other Distance related visualization and analysis
- ST_ClosestPoint
- ST_DFullyWithin
@@ -1166,7 +1169,7 @@
- ST_AsGeoJSON() return JSON formatted geometry (Olivier Courtin)
- Populate_Geometry_Columns() -- automatically add records to
geometry_columns for TABLES and VIEWS (Kevin Neufeld)
- -- ST_MinimumBoundingCircle() -- returns the smallest circle
+ -- ST_MinimumBoundingCircle() -- returns the smallest circle
polygon that can encompass a geometry (Bruce Rindahl)
- Enhancements
