[postgis-tickets] [PostGIS] #3539: geography ST_Segmentize returning straight line instead of curved
trac at osgeo.org
Thu Apr 28 14:14:15 PDT 2016
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> This appears to be a new regression which I am not seeing in PostGIS
> 2.2.2 install.
> When I tried this query in PostGIS 2.3.0 I'm getting a straight line
> instead of a curve.
> SELECT ST_AsText(ST_Segmentize(
> ST_MakeLine(ST_Point(-73.8893, 40.6975),
> ST_POINT(72.8667,19.1583))::geography, 10000000)::geometry);
> In 2.2.2 I get this which gets curvier as I reduce the segmentize meters
> LINESTRING(-73.8893 40.6975,19.6313806536934 62.1086776667385,72.8667
> 19.1583)
> In POSTGIS="2.3.0dev r14864" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel.
> 4.9.1, 04 March 2015" GDAL="GDAL 2.1.0dev, released 2015/99/99"
> LIBXML="2.7.8" LIBJSON="0.12" RASTER I get
> LINESTRING(-73.8893 40.6975,-0.511300000000007 29.9279,72.8667 19.1583)
> Look at snapshot for perspective.
> [[Image(bad_geog_segmentize.png)]]
New description:
This appears to be a new regression which I am not seeing in PostGIS 2.2.2
install.
instead of a curve.
POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1, 04
March 2015" GDAL="GDAL 2.0.2, released 2016/01/26" LIBXML="2.7.8"
19.1583)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3539#comment:3>
