[postgis-tickets] [PostGIS] #3618: --enable-debug is broken
trac at osgeo.org
Sat Sep 3 22:25:08 PDT 2016
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Keywords: |
I thought I had this issue before so hopefully this isn't a redundant
ticket.
When doing
./configure --enable-debug
Things don't compile. Breaks in geography.
gserialized_gist_2d.c:1:0: warning: -fPIC ignored for target (all code is
position independent) [enabled by default]
In file included from
C:/MING64~1/projects/POSTGR~1/rel/PG9~2.6W6/include/server/postgres.h:48:0,
from gserialized_gist_2d.c:41:
gserialized_gist_2d.c: In function
'gserialized_datum_predicate_box2df_geom_2d':
gserialized_gist_2d.c:644:68: error: 'b1' undeclared (first use in this
function)
POSTGIS_DEBUGF(3, "got boxes %s and %s", br1 ? box2df_to_string(&b1) :
"(null)", br2 ? box2df_to_string(&b2) : "(null)");
C:/MING64~1/projects/POSTGR~1/rel/PG9~2.6W6/include/server/utils/elog.h:107:14:
note: in definition of macro 'ereport_domain'
errfinish rest; \
../libpgcommon/lwgeom_pg.h:48:25: note: in expansion of macro 'ereport'
ereport((level < 1 || level > 5) ? DEBUG5 : (LOG
- level), (errmsg_internal("[%s:%s:%d] " msg, __FILE__, __func__,
__LINE__, __VA_ARGS__))); \
gserialized_gist_2d.c:644:3: note: in expansion of macro 'POSTGIS_DEBUGF'
gserialized_gist_2d.c:644:68: note: each undeclared identifier is reported
only once for each function it appears in
errfinish rest; \
<builtin>: recipe for target 'gserialized_gist_2d.o' failed
make[1]: *** [gserialized_gist_2d.o] Error 1
make[1]: Leaving directory '/projects/postgis/branches/2.3/postgis'
GNUmakefile:16: recipe for target 'all' failed
make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3618>
