[postgis-tickets] [PostGIS] #3615: ST_CreateOverview conflict on cast to regclass for duplicate table name
PostGIS trac at osgeo.org
Wed Sep 7 11:22:44 PDT 2016
  Reporter:  hypostase  |      Owner:  pramsey
      Type:  defect     |     Status:  reopened
  Priority:  medium     |  Milestone:  PostGIS 2.3.0
 Component:  postgis    |    Version:  2.2.x
Resolution:             |   Keywords:
Comment (by hypostase):
 No worries.
 There are three cases - no schema given, schema given with no other table
 of the same name, and schema given with the same name as the table in the
 search_path. - I'll do a combined test that checks all. Changing the
 search path should give you a passing test without the code change. (My
 original use case has a _lot_ of tables in parent child relationships in
 different schema used to control which users see what by default)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3615#comment:8>
