[postgis-tickets] r15085 - Really fix callback reading Edge data in presence of unexpected NULLs
Sandro Santilli
strk at kbt.io
Thu Sep 8 09:06:29 PDT 2016
Author: strk
Date: 2016-09-08 09:06:29 -0700 (Thu, 08 Sep 2016)
New Revision: 15085
trunk/topology/postgis_topology.c
Modified: trunk/topology/postgis_topology.c
--- trunk/topology/postgis_topology.c 2016-09-08 15:53:23 UTC (rev 15084)
+++ trunk/topology/postgis_topology.c 2016-09-08 16:06:29 UTC (rev 15085)
@@ -604,12 +604,13 @@
if ( isnull ) {
lwpgwarning("Found edge with NULL edge_id");
edge->edge_id = -1;
+ } else {
+ val = DatumGetInt32(dat);
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (edge_id)"
+ " has int32 val of %d",
+ colno, val);
+ edge->edge_id = val;
- val = DatumGetInt32(dat);
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (edge_id)"
- " has int32 val of %d",
- colno, val);
- edge->edge_id = val;
if ( fields & LWT_COL_EDGE_START_NODE ) {
@@ -617,66 +618,72 @@
if ( isnull ) {
lwpgwarning("Found edge with NULL start_node");
edge->start_node = -1;
+ } else {
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (start_node)"
+ " has int32 val of %d", colno, val);
+ edge->start_node = val;
- edge->start_node = val;
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (start_node)"
- " has int32 val of %d", colno, val);
if ( fields & LWT_COL_EDGE_END_NODE ) {
dat = SPI_getbinval(row, rowdesc, ++colno, &isnull);
if ( isnull ) {
lwpgwarning("Found edge with NULL end_node");
edge->end_node = -1;
+ } else {
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (end_node)"
+ edge->end_node = val;
- edge->end_node = val;
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (end_node)"
if ( fields & LWT_COL_EDGE_FACE_LEFT ) {
if ( isnull ) {
lwpgwarning("Found edge with NULL face_left");
edge->face_left = -1;
+ } else {
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (face_left)"
+ edge->face_left = val;
- edge->face_left = val;
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (face_left)"
if ( fields & LWT_COL_EDGE_FACE_RIGHT ) {
if ( isnull ) {
lwpgwarning("Found edge with NULL face_right");
edge->face_right = -1;
+ } else {
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (face_right)"
+ edge->face_right = val;
- edge->face_right = val;
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (face_right)"
if ( fields & LWT_COL_EDGE_NEXT_LEFT ) {
if ( isnull ) {
lwpgwarning("Found edge with NULL next_left");
edge->next_left = -1;
+ } else {
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (next_left)"
+ edge->next_left = val;
- edge->next_left = val;
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (next_left)"
if ( fields & LWT_COL_EDGE_NEXT_RIGHT ) {
if ( isnull ) {
lwpgwarning("Found edge with NULL next_right");
edge->next_right = -1;
+ } else {
+ POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (next_right)"
+ edge->next_right = val;
- edge->next_right = val;
- POSTGIS_DEBUGF(2, "fillEdgeFields: colno%d (next_right)"
if ( fields & LWT_COL_EDGE_GEOM ) {
