[postgis-tickets] [PostGIS] #3629: Getting failus on encoded line
trac at osgeo.org
Mon Sep 12 01:13:01 PDT 2016
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Keywords: windows, 32-bit |
This seems to be happening only for the 32-bit windows runs.
in_encodedpolyline .. failed (diff expected obtained:
/projects/postgis/tmp/2.2.3dev_pg9.5_geos3.5.0_gdal2.1.1w32/test_42_diff)
--- in_encodedpolyline_expected 2016-09-06 18:58:07 -0400
/projects/postgis/tmp/2.2.3dev_pg9.5_geos3.5.0_gdal2.1.1w32/test_42_out
2016-09-12 04:05:08 -0400
@@ -1,2 +1,2 @@
linefromencodedpolyline_01|SRID=4326;LINESTRING(-120.2 38.5,-120.95
40.7,-126.453 43.252)
-linefromencodedpolyline_02|SRID=4326;LINESTRING(-120.234472 38.5,-120.95
40.734352,-126.453 43.252)
+linefromencodedpolyline_02|SRID=4326;LINESTRING(-120.23447
38.5,-120.950002 40.73435,-126.453 43.252002)
Looks like a floating point precision issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3629>
