[postgis-tickets] r15096 - Revert ST_EstimatedExtent back to good ol'days when it returned WARNING instead of ERROR when no stats
Regina Obe lr at pcorp.us
Mon Sep 12 01:48:58 PDT 2016
Author: robe
Date: 2016-09-12 01:48:57 -0700 (Mon, 12 Sep 2016)
New Revision: 15096
   trunk/NEWS
   trunk/postgis/gserialized_estimate.c
   trunk/regress/estimatedextent_expected
   trunk/regress/sfcgal/tickets_expected
Closes #3396
Modified: trunk/NEWS
--- trunk/NEWS	2016-09-10 08:23:20 UTC (rev 15095)
+++ trunk/NEWS	2016-09-12 08:48:57 UTC (rev 15096)
@@ -8,6 +8,9 @@
   - #3604, pgcommon/Makefile.in orders CFLAGS incorrectly leading to
            wrong liblwgeom.h (Greg Troxel)
+  - #3396, ST_EstimatedExtent, throw WARNING instead of ERROR
+           (Regina Obe)
  * Deprecated signatures *
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c	2016-09-10 08:23:20 UTC (rev 15095)
+++ trunk/postgis/gserialized_estimate.c	2016-09-12 08:48:57 UTC (rev 15096)
@@ -2253,8 +2253,10 @@
 	nd_stats = pg_get_nd_stats_by_name(tbl_oid, col, 2, only_parent);
 	/* Error out on no stats */
-	if ( ! nd_stats )
-		elog(ERROR, "stats for \"%s.%s\" do not exist", tbl, text2cstring(col));
+	if ( ! nd_stats ) {
+		elog(WARNING, "stats for \"%s.%s\" do not exist", tbl, text2cstring(col));
+		PG_RETURN_NULL();
 	/* Construct the box */
 	gbox = palloc(sizeof(GBOX));
Modified: trunk/regress/estimatedextent_expected
--- trunk/regress/estimatedextent_expected	2016-09-10 08:23:20 UTC (rev 15095)
+++ trunk/regress/estimatedextent_expected	2016-09-12 08:48:57 UTC (rev 15096)
@@ -1,28 +1,41 @@
-ERROR:  stats for "t.g" do not exist
-WARNING:  ST_Estimated_Extent signature was deprecated in 2.1.0. Please use ST_EstimatedExtent
-#877.4|-10.15000|20.15000|-50.40000|30.40000
-#877.5|-10.15000|20.15000|-50.40000|30.40000
-ERROR:  stats for "c1.g" do not exist
-ERROR:  stats for "c2.g" do not exist
-ERROR:  stats for "p.g" do not exist
-#3391.4|0.00|1.00|0.00|1.00
-#3391.6|0.00|1.00|0.00|1.00
-#3391.7|0.00|1.00|0.00|1.00
-#3391.8|-1.00|0.00|-1.00|0.00
-#3391.9|-1.01|1.01|-1.01|1.01
-#3391.10|0.00|1.00|0.00|1.00
-#3391.11|-1.00|0.00|-1.00|0.00
-#3391.12|-1.01|2.02|-1.01|2.02
-#3391.17|0.00|1.00|0.00|1.00
-#3391.19|0.00|1.00|0.00|1.00
-#3391.20|0.00|1.00|0.00|1.00
-NOTICE:  drop cascades to 2 other objects
+WARNING:  stats for "t.g" do not exist
+#877.1|
+#877.2|
+WARNING:  ST_Estimated_Extent signature was deprecated in 2.1.0. Please use ST_EstimatedExtent
+#877.2.deprecated|
+#877.3||||
+#877.4|-10.15000|20.15000|-50.40000|30.40000
+#877.5|-10.15000|20.15000|-50.40000|30.40000
+WARNING:  stats for "c1.g" do not exist
+#3391.1||||
+WARNING:  stats for "c2.g" do not exist
+#3391.2||||
+WARNING:  stats for "p.g" do not exist
+#3391.3||||
+#3391.4|0.00|1.00|0.00|1.00
+#3391.5||||
+#3391.6|0.00|1.00|0.00|1.00
+#3391.7|0.00|1.00|0.00|1.00
+#3391.8|-1.00|0.00|-1.00|0.00
+#3391.9|-1.01|1.01|-1.01|1.01
+#3391.10|0.00|1.00|0.00|1.00
+#3391.11|-1.00|0.00|-1.00|0.00
+#3391.12|-1.01|2.02|-1.01|2.02
+#3391.13||||
+#3391.14||||
+#3391.15||||
+#3391.16||||
+#3391.17|0.00|1.00|0.00|1.00
+#3391.18||||
+#3391.19|0.00|1.00|0.00|1.00
+#3391.20|0.00|1.00|0.00|1.00
+NOTICE:  drop cascades to 2 other objects
Modified: trunk/regress/sfcgal/tickets_expected
--- trunk/regress/sfcgal/tickets_expected	2016-09-10 08:23:20 UTC (rev 15095)
+++ trunk/regress/sfcgal/tickets_expected	2016-09-12 08:48:57 UTC (rev 15096)
@@ -1,243 +1,247 @@
-#2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
-#11|0
-WARNING:  ST_Locate_Between_Measures and ST_Locate_Along_Measure were deprecated in 2.2.0. Please use ST_LocateAlong and ST_LocateBetween
-#21|SRID=31293;POINTM(6220.13 5337367.145 4566)
-t
-ERROR:  AddGeometryColumn() - invalid SRID
-#44|t|t
-#58|220187|150406|220289|150507
-ERROR:  lwgeom_to_gml2: 'CurvePolygon' geometry type not supported
-#66|CIRCULARSTRING(0 0,1 1,2 2)
-#68a|MULTIPOINT(1 3,4 5)
-ERROR:  lwgeom_longitude_shift: unsupported geom type: CircularString
-#69|CIRCULARSTRING(220269 150417,220228 150507,220228 150408)
-#70|3
-#73|GEOMETRYCOLLECTION(CIRCULARSTRING(1 1,2 3,4 5,6 7,5 6))
-#80|MULTILINESTRING((0 0,1 1))
-#83|MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406))
-ERROR:  LWGEOM2SFCGAL: Unknown geometry type !
-#112|GEOMETRYCOLLECTION(POINT(-10 50))
-ERROR:  Geometry argument does not have an 'M' ordinate
-#116|POLYGON EMPTY
-#122|CIRCULARSTRING(220268 150415,220227 150505,220227 150406)
-#124a|COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30 5),CIRCULARSTRING(30 5,34 56,67 89))
-ERROR:  incontinuous compound curve
-#145a|POLYGON EMPTY
-#145b|0
-#146|0|t|GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1 2,2 3))
-ERROR:  Invalid hex string, length (267) has to be a multiple of two!
-#157|ST_Polygon|POLYGON
-#157|ST_Point|POINT
-#157|ST_CurvePolygon|CURVEPOLYGON
-#157|ST_CircularString|CIRCULARSTRING
-#168|3|MULTIPOLYGON ZM (((4275341.96977851 259186.966993061 1323.76295828331 -1.79769313486232e+308,4275341.96977851 259186.966993061 1323.76295828331 -1.79769313486232e+308,4275341.96977851 259186.966993061 1323.76295828331 -1.79769313486232e+308)))|IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
-#175|SRID=26915;POINT(482020 4984378)
-#178a|0
-#178b|5
-NOTICE:  No points or linestrings in input array
-#179a|
-#179b|
-#183|COMPOUNDCURVE(CIRCULARSTRING(0 0,0.5 1.2071067812,1 0),(1 0,0 1))
-#210a|
-#210b|
-#213|17
-#234|COMPOUNDCURVE((0 0,1 1))
-#241|0
-#254|GEOMETRYCOLLECTION EMPTY
-#259|
-#260|1667701
-#261|0
-#262|POINT(-119.5434 34.9438)|t|t|t
-#262|POINT(-119.5452 34.9442)|t|t|t
-#262|POINT(-119.5438 34.9443)|t|t|t
-#263|SRID=4326;POINT(-119.5434 34.9438)|t|t|t
-#263|SRID=4326;POINT(-119.5452 34.9442)|t|t|t
-#263|SRID=4326;POINT(-119.5438 34.9443)|t|t|t
-#271|t
-#272|-2|2
-#277|<gml:Point><gml:coordinates>1,1e+308</gml:coordinates></gml:Point>
-#299|2
-#304
-#304.a|21
-#304.b|1
-#408|Too few points in geometry component[
-NOTICE:  Too few points in geometry component at or near point 0 0
-#408.1|f
-#408.2|Too few points in geometry component[0 0]
-NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing found 2 - must be 0 or >= 4
-#408.3|f
-#408.4|IllegalArgumentException: Invalid number of points in LinearRing found 2 - must be 0 or >= 4
-#457.1|POINT(0 0)
-#457.2|LINESTRING EMPTY
-#457.3|POLYGON EMPTY
-#457.4|POINT EMPTY
-#457.5|LINESTRING(0 0,1 1)
-#457.6|POLYGON EMPTY
-#457.7|POINT EMPTY
-#457.8|LINESTRING EMPTY
-#457.9|POLYGON((0 0,1 0,1 1,0 1,0 0))
-#835.1|POINT EMPTY
-#835.2|LINESTRING EMPTY
-#835.3|POLYGON EMPTY
-#835.4|POINT EMPTY
-#835.5|LINESTRING EMPTY
-#835.6|POLYGON EMPTY
-#835.7|POINT EMPTY
-#835.8|LINESTRING EMPTY
-#835.9|POLYGON EMPTY
-#835.10|MULTIPOINT EMPTY
-#835.11|MULTILINESTRING EMPTY
-#835.12|MULTIPOLYGON EMPTY
-#650|MULTIPOINT(0 0,1 1,2 2)
-#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30 40))
-#677|1121395
-#680|01d107000000000000000024c000000000000049400000000000000040
-#681a|
-#681b|
-#681c|
-#681d|
-#681e|
-#681f|
-#681g|
-#682|POLYGON EMPTY
-#683|POLYGON EMPTY
-#684,#2109|SRID=4326;POINT EMPTY
-#2109|SRID=3395;POINT EMPTY
-#685|POLYGON EMPTY
-#686|GEOMETRYCOLLECTION(POLYGON EMPTY,TRIANGLE EMPTY)
-#687|f
-#689|f
-#690
-010200000003000000f771d98de33826c00000000000004440f771d98de33826c000000000008051400000000000805140f771d98de33826c0
-#693a|POLYGON M ((-71.1319 42.2503 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319 42.2503 0))
-#693b|POLYGON M ((-71.1319 42.2512 0,-71.1318 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132 42.2511 6,-71.1319 42.2512 30))
-#694
-ERROR:  Shell is not a line
-#695
-ERROR:  First argument must be a LINESTRING
-#696|POLYHEDRALSURFACE Z (((0 0 0,0 0 1,0 1 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)),((1 1 0,1 1 1,1 0 1,1 0 0,1 1 0)),((0 1 0,0 1 1,1 1 1,1 1 0,0 1 0)),((0 0 1,1 0 1,1 1 1,0 1 1,0 0 1)))
-#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54 11028513.63)
-#723|POINT(-11.11111 40)
-#723|GEOMETRYCOLLECTION EMPTY
-#723|POINT(-11.11111 55)
-#804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos srsDimension="2">0 0</gml:pos></gml:Point>
-#845|t
-#834|GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(10 0,10 10))
-#884|1|f
-#884|2|t
-#938|
-#668|BOX(10 2,14 2)
-#711|
-#712|t
-#756.1|t|t
-#1023|t
-#1023.a|f
-#1023.b|t
-#1060|FFFFFFFF2
-#1273|t
-#1273.1|t
-#1292|GEOMETRYCOLLECTION(POINT(180 90),POLYGON((140 50,150 50,180 50,140 50),(140 60,150 60,180 60,140 60)))
-NOTICE:  Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY
-#1292.1|POINT(180 85)|POINT(-175 90)
-<#1320>
-#1320.geog.1|MULTIPOLYGON|4326
-#1320.geom.1|MULTIPOLYGON|4326
-ERROR:  Geometry type (Polygon) does not match column type (MultiPolygon)
-#1320.geog.2|MULTIPOLYGON|4326
-#1320.geom.2|MULTIPOLYGON|4326
-#1320.geog.3|MULTIPOLYGON|4326
-#1320.geom.3|MULTIPOLYGON|4326
-</#1320>
-#1344|25
-#1385|
-#657.1|-166.78
-#657.2|10.00
-#657.3|t
-#1305.1|POINT(10 10)
-#1305.2|t
-#1305.3|t
-ERROR:  MultiPolygon cannot contain MultiPoint element at character 8
-ERROR:  MultiLineString cannot contain MultiPoint element at character 8
-ERROR:  MultiPoint cannot contain MultiPoint element at character 8
-ERROR:  CompoundCurve cannot contain MultiPoint element at character 8
-ERROR:  MultiCurve cannot contain MultiPoint element at character 8
-ERROR:  MultiSurface cannot contain MultiPoint element at character 8
-#1453.1|t
-#1453.2|f
-#1454|t
-#1414|CURVEPOLYGON Z EMPTY
-#1478|POINT EMPTY
-#745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
-#1450|POINT|POLYGON
-#1482|4326
-#852.1|1|f|f
-#852.1|2|f|f
-#852.2|1|t|t
-#852.2|2|t|t
-#1489|MULTIPOINT EMPTY|0|MULTILINESTRING EMPTY|0|MULTIPOLYGON EMPTY|0|GEOMETRYCOLLECTION EMPTY|0
-ERROR:  AddToPROJ4SRSCache: could not parse proj4 string ''
-#1038|
-#1042|2
-#1170|90
-#1264|t
-#1398a|POINT(-119.093153 45.632669)
-#1398b|POINT(-160.137654 77.091608)
-#1543|MULTILINESTRING((0 0,10 0,10 10,0 0),(0 0))|POLYGON((0 0,10 10,10 0,0 0))
-#1580.1|Point[S]
-ERROR:  transform: couldn't project point (180 90 0): tolerance condition error (-20)
-#1580.3|Point[S]
-#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
-ERROR:  invalid SRID: 330000 not found in spatial_ref_sys
-#1596.3|3395
-ERROR:  invalid SRID: 999000 not found in spatial_ref_sys
-#1596.5|3395
-NOTICE:  SRID value -1 converted to the officially unknown SRID value 0
-#1596.6|public.road_pg.roads_geom SRID changed to 0
-#1596.7|0
-#1596|Point[GS]
-#1695|MULTIPOLYGON EMPTY
-#1697.1|0
-#1697.2|0
-#1697.3|1024
-#1734.1|1026
-#1755|POINT Z (85 35 0)
-#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
-#1780|t
-#1791|4.7
-ERROR:  ST_Segmentize: invalid max_distance 0 (must be >= 0)
-ERROR:  invalid GML representation
-#1978|3.1416
-#1996|{"type":"Point","coordinates":[]}
-#2001|POLYGON((0 0,0 1,1 1,0 0))
-#2028|TIN(((0 0,0 1,1 1,0 0)))
-#2035a|6
-#2035b|6
-#2048|1|f|f
-#2048|2|t|t
-#2048|3|f|f
-#2112a|0|LINESTRING(2.5 2.5 1,2.5 2.5 1)
-#2112b|1|LINESTRING(1 1 1,1 0 1)
-#2108|SRID=3395;POINTM EMPTY
-#2117|SRID=3395;POINTM EMPTY
-#2110.1|f
-#2110.2|t
-#2110.3|t
-#2145|6792004
+#2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
+#11|0
+WARNING:  ST_Locate_Between_Measures and ST_Locate_Along_Measure were deprecated in 2.2.0. Please use ST_LocateAlong and ST_LocateBetween
+#21|SRID=31293;POINTM(6220.13 5337367.145 4566)
+t
+ERROR:  AddGeometryColumn() - invalid SRID
+#44|t|t
+#58|220187|150406|220289|150507
+ERROR:  lwgeom_to_gml2: 'CurvePolygon' geometry type not supported
+#66|CIRCULARSTRING(0 0,1 1,2 2)
+#68a|MULTIPOINT(1 3,4 5)
+ERROR:  lwgeom_longitude_shift: unsupported geom type: CircularString
+#69|CIRCULARSTRING(220269 150417,220228 150507,220228 150408)
+#70|3
+#73|GEOMETRYCOLLECTION(CIRCULARSTRING(1 1,2 3,4 5,6 7,5 6))
+#80|MULTILINESTRING((0 0,1 1))
+#83|MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406))
+ERROR:  LWGEOM2SFCGAL: Unknown geometry type !
+#112|GEOMETRYCOLLECTION(POINT(-10 50))
+ERROR:  Geometry argument does not have an 'M' ordinate
+#116|POLYGON EMPTY
+#122|CIRCULARSTRING(220268 150415,220227 150505,220227 150406)
+#124a|COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30 5),CIRCULARSTRING(30 5,34 56,67 89))
+ERROR:  incontinuous compound curve
+#145a|POLYGON EMPTY
+#145b|0
+#146|0|t|GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1 2,2 3))
+ERROR:  Invalid hex string, length (267) has to be a multiple of two!
+#157|ST_Polygon|POLYGON
+#157|ST_Point|POINT
+#157|ST_CurvePolygon|CURVEPOLYGON
+#157|ST_CircularString|CIRCULARSTRING
+#168|3|MULTIPOLYGON ZM (((4275341.96977851 259186.966993061 1323.76295828331 -1.79769313486232e+308,4275341.96977851 259186.966993061 1323.76295828331 -1.79769313486232e+308,4275341.96977851 259186.966993061 1323.76295828331 -1.79769313486232e+308)))|IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
+#175|SRID=26915;POINT(482020 4984378)
+#178a|0
+#178b|5
+NOTICE:  No points or linestrings in input array
+#179a|
+#179b|
+#183|COMPOUNDCURVE(CIRCULARSTRING(0 0,0.5 1.2071067812,1 0),(1 0,0 1))
+#210a|
+#210b|
+#213|17
+#234|COMPOUNDCURVE((0 0,1 1))
+#241|0
+#254|GEOMETRYCOLLECTION EMPTY
+#259|
+#260|1667701
+#261|0
+#262|POINT(-119.5434 34.9438)|t|t|t
+#262|POINT(-119.5452 34.9442)|t|t|t
+#262|POINT(-119.5438 34.9443)|t|t|t
+#263|SRID=4326;POINT(-119.5434 34.9438)|t|t|t
+#263|SRID=4326;POINT(-119.5452 34.9442)|t|t|t
+#263|SRID=4326;POINT(-119.5438 34.9443)|t|t|t
+#271|t
+#272|-2|2
+#277|<gml:Point><gml:coordinates>1,1e+308</gml:coordinates></gml:Point>
+#299|2
+#304
+#304.a|21
+#304.b|1
+#408|Too few points in geometry component[
+NOTICE:  Too few points in geometry component at or near point 0 0
+#408.1|f
+#408.2|Too few points in geometry component[0 0]
+NOTICE:  IllegalArgumentException: Invalid number of points in LinearRing found 2 - must be 0 or >= 4
+#408.3|f
+#408.4|IllegalArgumentException: Invalid number of points in LinearRing found 2 - must be 0 or >= 4
+#457.1|POINT(0 0)
+#457.2|LINESTRING EMPTY
+#457.3|POLYGON EMPTY
+#457.4|POINT EMPTY
+#457.5|LINESTRING(0 0,1 1)
+#457.6|POLYGON EMPTY
+#457.7|POINT EMPTY
+#457.8|LINESTRING EMPTY
+#457.9|POLYGON((0 0,1 0,1 1,0 1,0 0))
+#835.1|POINT EMPTY
+#835.2|LINESTRING EMPTY
+#835.3|POLYGON EMPTY
+#835.4|POINT EMPTY
+#835.5|LINESTRING EMPTY
+#835.6|POLYGON EMPTY
+#835.7|POINT EMPTY
+#835.8|LINESTRING EMPTY
+#835.9|POLYGON EMPTY
+#835.10|MULTIPOINT EMPTY
+#835.11|MULTILINESTRING EMPTY
+#835.12|MULTIPOLYGON EMPTY
+#650|MULTIPOINT(0 0,1 1,2 2)
+#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30 40))
+#677|1121395
+#680|01d107000000000000000024c000000000000049400000000000000040
+#681a|
+#681b|
+#681c|
+#681d|
+#681e|
+#681f|
+#681g|
+#682|POLYGON EMPTY
+#683|POLYGON EMPTY
+#684,#2109|SRID=4326;POINT EMPTY
+#2109|SRID=3395;POINT EMPTY
+#685|POLYGON EMPTY
+#686|GEOMETRYCOLLECTION(POLYGON EMPTY,TRIANGLE EMPTY)
+#687|f
+#689|f
+#690
+010200000003000000f771d98de33826c00000000000004440f771d98de33826c000000000008051400000000000805140f771d98de33826c0
+#693a|POLYGON M ((-71.1319 42.2503 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319 42.2503 0))
+#693b|POLYGON M ((-71.1319 42.2512 0,-71.1318 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132 42.2511 6,-71.1319 42.2512 30))
+#694
+ERROR:  Shell is not a line
+#695
+ERROR:  First argument must be a LINESTRING
+#696|POLYHEDRALSURFACE Z (((0 0 0,0 0 1,0 1 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)),((1 1 0,1 1 1,1 0 1,1 0 0,1 1 0)),((0 1 0,0 1 1,1 1 1,1 1 0,0 1 0)),((0 0 1,1 0 1,1 1 1,0 1 1,0 0 1)))
+#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54 11028513.63)
+#723|POINT(-11.11111 40)
+#723|GEOMETRYCOLLECTION EMPTY
+#723|POINT(-11.11111 55)
+#804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos srsDimension="2">0 0</gml:pos></gml:Point>
+#845|t
+#834|GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(10 0,10 10))
+#884|1|f
+#884|2|t
+#938|
+#668|BOX(10 2,14 2)
+#711|
+#712|t
+#756.1|t|t
+#1023|t
+#1023.a|f
+#1023.b|t
+#1060|FFFFFFFF2
+#1273|t
+#1273.1|t
+#877.1|
+#877.2|
+#877.2.deprecated|
+#877.3||||
+#1292|GEOMETRYCOLLECTION(POINT(180 90),POLYGON((140 50,150 50,180 50,140 50),(140 60,150 60,180 60,140 60)))
+NOTICE:  Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY
+#1292.1|POINT(180 85)|POINT(-175 90)
+<#1320>
+#1320.geog.1|MULTIPOLYGON|4326
+#1320.geom.1|MULTIPOLYGON|4326
+ERROR:  Geometry type (Polygon) does not match column type (MultiPolygon)
+#1320.geog.2|MULTIPOLYGON|4326
+#1320.geom.2|MULTIPOLYGON|4326
+#1320.geog.3|MULTIPOLYGON|4326
+#1320.geom.3|MULTIPOLYGON|4326
+</#1320>
+#1344|25
+#1385|
+#657.1|-166.78
+#657.2|10.00
+#657.3|t
+#1305.1|POINT(10 10)
+#1305.2|t
+#1305.3|t
+ERROR:  MultiPolygon cannot contain MultiPoint element at character 8
+ERROR:  MultiLineString cannot contain MultiPoint element at character 8
+ERROR:  MultiPoint cannot contain MultiPoint element at character 8
+ERROR:  CompoundCurve cannot contain MultiPoint element at character 8
+ERROR:  MultiCurve cannot contain MultiPoint element at character 8
+ERROR:  MultiSurface cannot contain MultiPoint element at character 8
+#1453.1|t
+#1453.2|f
+#1454|t
+#1414|CURVEPOLYGON Z EMPTY
+#1478|POINT EMPTY
+#745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
+#1450|POINT|POLYGON
+#1482|4326
+#852.1|1|f|f
+#852.1|2|f|f
+#852.2|1|t|t
+#852.2|2|t|t
+#1489|MULTIPOINT EMPTY|0|MULTILINESTRING EMPTY|0|MULTIPOLYGON EMPTY|0|GEOMETRYCOLLECTION EMPTY|0
+ERROR:  AddToPROJ4SRSCache: could not parse proj4 string ''
+#1038|
+#1042|2
+#1170|90
+#1264|t
+#1398a|POINT(-119.093153 45.632669)
+#1398b|POINT(-160.137654 77.091608)
+#1543|MULTILINESTRING((0 0,10 0,10 10,0 0),(0 0))|POLYGON((0 0,10 10,10 0,0 0))
+#1580.1|Point[S]
+ERROR:  transform: couldn't project point (180 90 0): tolerance condition error (-20)
+#1580.3|Point[S]
+#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
+ERROR:  invalid SRID: 330000 not found in spatial_ref_sys
+#1596.3|3395
+ERROR:  invalid SRID: 999000 not found in spatial_ref_sys
+#1596.5|3395
+NOTICE:  SRID value -1 converted to the officially unknown SRID value 0
+#1596.6|public.road_pg.roads_geom SRID changed to 0
+#1596.7|0
+#1596|Point[GS]
+#1695|MULTIPOLYGON EMPTY
+#1697.1|0
+#1697.2|0
+#1697.3|1024
+#1734.1|1026
+#1755|POINT Z (85 35 0)
+#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
+#1780|t
+#1791|4.7
+ERROR:  ST_Segmentize: invalid max_distance 0 (must be >= 0)
+ERROR:  invalid GML representation
+#1978|3.1416
+#1996|{"type":"Point","coordinates":[]}
+#2001|POLYGON((0 0,0 1,1 1,0 0))
+#2028|TIN(((0 0,0 1,1 1,0 0)))
+#2035a|6
+#2035b|6
+#2048|1|f|f
+#2048|2|t|t
+#2048|3|f|f
+#2112a|0|LINESTRING(2.5 2.5 1,2.5 2.5 1)
+#2112b|1|LINESTRING(1 1 1,1 0 1)
+#2108|SRID=3395;POINTM EMPTY
+#2117|SRID=3395;POINTM EMPTY
+#2110.1|f
+#2110.2|t
+#2110.3|t
+#2145|6792004
