[postgis-tickets] r15107 - #3569, Incorrect coordinates returned by ST_CollectionHomogenize
Daniel Baston
dbaston at gmail.com
Tue Sep 13 12:14:05 PDT 2016
Author: dbaston
Date: 2016-09-13 12:14:05 -0700 (Tue, 13 Sep 2016)
New Revision: 15107
branches/2.2/NEWS
branches/2.2/liblwgeom/liblwgeom.h.in
branches/2.2/postgis/lwgeom_functions_basic.c
branches/2.2/regress/tickets.sql
branches/2.2/regress/tickets_expected
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-09-13 19:09:17 UTC (rev 15106)
+++ branches/2.2/NEWS 2016-09-13 19:14:05 UTC (rev 15107)
@@ -14,6 +14,8 @@
- #3573, Operator <<->> incorrectly calculates m distance
- #3579, Crash in LWGEOM2GEOS
- #3515, tiger_data not being backed up
+ - #3569, Incorrect coordinates returned by ST_CollectionHomogenize
+ (Dan Baston)
- #3602, perl as found by configure is not used
in tiger extension, postgis_sfcgal, address_standardizer
- #3607, Fix inconsistency with multilinestring in
Modified: branches/2.2/liblwgeom/liblwgeom.h.in
--- branches/2.2/liblwgeom/liblwgeom.h.in 2016-09-13 19:09:17 UTC (rev 15106)
+++ branches/2.2/liblwgeom/liblwgeom.h.in 2016-09-13 19:14:05 UTC (rev 15107)
@@ -1027,7 +1027,12 @@
extern int lwcollection_ngeoms(const LWCOLLECTION *col);
-/* Given a generic geometry/collection, return the "simplest" form. */
+/* Given a generic geometry/collection, return the "simplest" form.
+ * The elements of the homogenized collection are references to the
+ * input geometry; a deep clone is not performed.
+ * TODO: consider returning a geometry that does not reference the
+ * input
extern LWGEOM *lwgeom_homogenize(const LWGEOM *geom);
Modified: branches/2.2/postgis/lwgeom_functions_basic.c
--- branches/2.2/postgis/lwgeom_functions_basic.c 2016-09-13 19:09:17 UTC (rev 15106)
+++ branches/2.2/postgis/lwgeom_functions_basic.c 2016-09-13 19:14:05 UTC (rev 15107)
@@ -2584,14 +2584,17 @@
lwoutput = lwgeom_homogenize(lwgeom);
lwgeom_free(lwgeom);
- PG_FREE_IF_COPY(input, 0);
if ( ! lwoutput )
PG_RETURN_NULL();
+ PG_FREE_IF_COPY(input, 0);
output = geometry_serialize(lwoutput);
lwgeom_free(lwoutput);
PG_RETURN_POINTER(output);
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql 2016-09-13 19:09:17 UTC (rev 15106)
+++ branches/2.2/regress/tickets.sql 2016-09-13 19:14:05 UTC (rev 15107)
@@ -950,6 +950,13 @@
-- #3565
SELECT '#3565',ST_SetPoint(st_geomfromtext('LINESTRING EMPTY'), 0, ST_MakePoint(1,1));
+-- #3569
+WITH clustr AS (
+ SELECT ST_Polygonize(ST_MakeEnvelope(1, 2, 3, 4)) AS geom
+ SELECT '#3569', ST_CollectionHomogenize(geom)::box2d
+ FROM clustr;
-- #3579
with
params as (
Modified: branches/2.2/regress/tickets_expected
--- branches/2.2/regress/tickets_expected 2016-09-13 19:09:17 UTC (rev 15106)
+++ branches/2.2/regress/tickets_expected 2016-09-13 19:14:05 UTC (rev 15107)
@@ -292,6 +292,7 @@
#3470|t
#3470b|50
ERROR: Cannot set point values on EMPTY geometry, use ST_AddPoint to add points
+#3569|BOX(1 2,3 4)
#3579|f|t
#3583|MULTIPOLYGON Z (EMPTY)
#3627a|o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?
