[postgis-tickets] [PostGIS] #3632: getFaceByPoint test relies on invalid topology
trac at osgeo.org
Wed Sep 14 08:30:41 PDT 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: topology | Version: 2.2.x
Keywords: |
Trying a faster Point-In-Polygon test I found that
topology/test/regress/getfacebypoint.sql is expecting a debating result
for the test 't5'.
The argument point falls within an "inner" face but the "inner" face isn't
correctly registered but rather marked as being part of the universe face.
This is an invalid topology, constructed via AddEdge/AddFace calls within
the test itself.
I suggest the topology is corrected and both a test for point-in-hole and
point-in-universe replace the existing 't5' test.
Andrea: adding you in Cc as I believe you were the author of that test
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3632>
