[postgis-tickets] [PostGIS] #3633: PostGIS upgrade is broken - operator does not exist: gidx public.&& geography
trac at osgeo.org
Sun Sep 18 02:06:47 PDT 2016
geography
Reporter: komzpa | Owner: robe
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.2.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
komzpa,
I ran into this myself. I'm guessing you were trying to upgrade from an
earlier 2.3.0.
So this would be a non-issue for production upgrades.
The reason you are getting this is because of the BRIN introduction, and
our upgrade logic can't handle index binding changes within a micro
update. So since you are going from a 2.3.0 before brin was introduced to
2.3.0 after brin, you are having this issue.
As I recall when testing upgrading from a 2.2 to 2.3.0 this was a non-
issue.
To fix, as I recall, I had to take out the
IF 203 > ... wrapper around the BRIN stuff so that the brin operators and
families could be created.
-- Operator family brin_geography_inclusion_ops brin -- LastUpdated: 203
DO LANGUAGE 'plpgsql'
$postgis_proc_upgrade$
BEGIN
IF 203 > version_from_num FROM _postgis_upgrade_info THEN
EXECUTE $postgis_proc_upgrade_parsed_def$ CREATE OPERATOR FAMILY
brin_geography_inclusion_ops USING brin;
-- Availability: 2.3.0
CREATE OR REPLACE FUNCTION geog_brin_inclusion_add_value(internal,
internal, internal, internal) RETURNS boolean
AS '$libdir/postgis-2.3','geog_brin_inclusion_add_value'
LANGUAGE 'c';
CREATE OPERATOR CLASS brin_geography_inclusion_ops
DEFAULT FOR TYPE geography
USING brin
FAMILY brin_geography_inclusion_ops AS
OPERATOR 3 &&(geography, geography),
FUNCTION 1 brin_inclusion_opcinfo(internal) ,
FUNCTION 2 geog_brin_inclusion_add_value(internal,
internal, internal, internal) ,
FUNCTION 3 brin_inclusion_consistent(internal, internal,
internal) ,
FUNCTION 4 brin_inclusion_union(internal, internal,
internal) ,
STORAGE gidx;
ALTER OPERATOR FAMILY brin_geography_inclusion_ops USING brin ADD
OPERATOR 3 &&(gidx, geography),
OPERATOR 3 &&(geography, gidx),
OPERATOR 3 &&(gidx, gidx);
$postgis_proc_upgrade_parsed_def$;
END IF;
END
$postgis_proc_upgrade$;
I think strk has a ticket in place already for this kind of thing (to make
dev upgrades possible even in these cases) though I can't find it at
moment
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3633#comment:4>
