[postgis-tickets] [PostGIS] #3635: utils/create_spatial_ref_sys_config_dump.pl has hardcoded perl path
PostGIS trac at osgeo.org
Mon Sep 19 18:24:19 PDT 2016
 Reporter:  gdt                    |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 2.3.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 This script starts with "#!/usr/bin/perl", but some systems (e.g.
 NetBSD/pkgsrc) do not include perl in the base system, placing it
 elsewhere  (e.g. /usr/pkg/bin/perl).
 Arguably the 100% correct solution is to substitute the perl path found by
 configure, but that's hard. Instead, use env to find perl
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3635>
