[postgis-tickets] [PostGIS] #3636: AddGeomtryColumn is not parallel safe
trac at osgeo.org
Tue Sep 20 06:53:18 PDT 2016
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Keywords: |
shp2pgsql -s 3857 -g geom -I data/osm/water_polygons.shp water_polygons |
psql
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
Expanded display is used automatically.
Null display is "ยค".
Line style is unicode.
Border style is 2.
Timing is on.
SET
Time: 0,189 ms
SET
Time: 0,058 ms
BEGIN
Time: 0,034 ms
CREATE TABLE
Time: 3,782 ms
ALTER TABLE
Time: 1,649 ms
ERROR: 25000: cannot execute ALTER TABLE during a parallel operation
CONTEXT: SQL statement "ALTER TABLE public.water_polygons ADD COLUMN geom
geometry(MultiPolygon, 3857)"
PL/pgSQL function addgeometrycolumn(character varying,character
varying,character varying,character varying,integer,character
varying,integer,boolean) line 110 at EXECUTE
SQL statement "SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7)"
varying,character varying,integer,character varying,integer,boolean) line
5 at SQL statement
parallel worker
Time: 51,580 ms
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3636>
