[postgis-tickets] r15125 - forgot to update ChangeLog on RC1, too late but lets bring it up to date a bit.
Regina Obe
lr at pcorp.us
Wed Sep 21 08:58:27 PDT 2016
Author: robe
Date: 2016-09-21 08:58:27 -0700 (Wed, 21 Sep 2016)
New Revision: 15125
trunk/ChangeLog
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2016-09-20 21:01:40 UTC (rev 15124)
+++ trunk/ChangeLog 2016-09-21 15:58:27 UTC (rev 15125)
@@ -1,3 +1,216 @@
+2016-09-20 21:01 Regina Obe <lr at pcorp.us>
+ * [r15124] postgis/postgis.sql.in: AddGeometryColumn should not be
+ marked parallel safe
+ closes #3636
+2016-09-19 05:21 Regina Obe <lr at pcorp.us>
+ * [r15122] Version.config, extensions/upgradeable_versions.mk: flip
+ back to 2.3.0dev until release time
+2016-09-19 05:17 Regina Obe <lr at pcorp.us>
+ * [r15120] Version.config, extensions/upgradeable_versions.mk: flip
+ switch to PostGIS 2.3.0rc1
+2016-09-19 04:54 Regina Obe <lr at pcorp.us>
+ * [r15118] doc/faq_raster.xml, doc/reference_constructor.xml,
+ doc/reference_raster.xml: doc corrections from ruvyn for PostGIS
+ 2.3
+ references #3581
+ references #3580
+ references #3586
+ references #3575
+2016-09-19 04:00 Regina Obe <lr at pcorp.us>
+ * [r15117] raster/rt_pg/rtpostgis.sql.in: missed another schema
+ qualify
+2016-09-19 03:42 Regina Obe <lr at pcorp.us>
+ * [r15116] raster/rt_pg/rtpostgis.sql.in: missed some schema
+ qualify
+2016-09-18 23:41 Regina Obe <lr at pcorp.us>
+ * [r15114] raster/rt_pg/rtpostgis.sql.in: use ST_Union instead of
+ ST_Collect to compute max extent
+ References #3501 for PostGIS 2.3.0 trunk
+2016-09-16 09:16 Sandro Santilli <strk at kbt.io>
+ * [r15113] topology/postgis_topology.c: Early release memory used
+ by SPI executed topology callback queries
+2016-09-14 16:04 Daniel Baston <dbaston at gmail.com>
+ * [r15109] liblwgeom/cunit/cu_algorithm.c,
+ liblwgeom/liblwgeom.h.in, liblwgeom/lwpoly.c,
+ postgis/lwgeom_functions_analytic.c, postgis/postgis.sql.in,
+ regress/tickets.sql, regress/tickets_expected: New method to
+ approximate minimum bounding circle polygon without using
+ ST_Buffer. (References #2841, #3620)
+2016-09-14 13:37 Daniel Baston <dbaston at gmail.com>
+ * [r15108] .gitignore: gitignore updates (ignore gcov output)
+2016-09-13 18:06 Daniel Baston <dbaston at gmail.com>
+ * [r15105] liblwgeom/liblwgeom.h.in,
+ postgis/lwgeom_functions_basic.c, regress/tickets.sql,
+ regress/tickets_expected: #3569, Incorrect coordinates returned
+ by ST_CollectionHomogenize
+2016-09-13 16:55 Regina Obe <lr at pcorp.us>
+ * [r15104] regress/in_encodedpolyline.sql,
+ regress/in_encodedpolyline_expected: Add ST_SnapToGrid so 32-bit
+ and 64-bit answers agree
+ References #3629 for PostGIS 2.3
+2016-09-13 08:38 Sandro Santilli <strk at kbt.io>
+ * [r15102] topology/sql/populate.sql.in: Fix DEBUG build of
+ topology
+2016-09-12 18:00 Sandro Santilli <strk at kbt.io>
+ * [r15101] .editorconfig, regress/sfcgal/tickets_expected: Re-add
+ accidentally removed trailing spaces in an _expected file
+ Also tweak .editorconfig to avoid this accident in the future
+ Fixes #3630
+2016-09-12 16:17 Sandro Santilli <strk at kbt.io>
+ * [r15100] raster/rt_pg/Makefile.in: Remove generated file on make
+ clean
+ * [r15099] raster/rt_pg/Makefile.in: Remove trailing spaces
+2016-09-12 16:01 Sandro Santilli <strk at kbt.io>
+ * [r15098] regress/estimatedextent_expected,
+ regress/sfcgal/tickets_expected: Remove carriage returns from
+ regression tests
+ * [r15097] .gitignore: Ignore new generated files
+2016-09-12 08:48 Regina Obe <lr at pcorp.us>
+ * [r15096] NEWS, postgis/gserialized_estimate.c,
+ regress/estimatedextent_expected,
+ regress/sfcgal/tickets_expected: Revert ST_EstimatedExtent back
+ to good ol'days when it returned WARNING instead of ERROR when no
+ stats
+ Closes #3396
+2016-09-09 21:19 Sandro Santilli <strk at kbt.io>
+ * [r15094] .drone.yml: Reduce data transfer on drone agent git
+ fetch (--depth 20)
+2016-09-09 14:23 Sandro Santilli <strk at kbt.io>
+ * [r15092] regress/swapordinates.sql,
+ regress/swapordinates_expected: Add test for ST_SwapOrdinate fix
+ (#3628)
+2016-09-09 14:16 Sandro Santilli <strk at kbt.io>
+ * [r15089] raster/test/regress/rt_createoverview.sql,
+ raster/test/regress/rt_createoverview_expected: Add complete test
+ for RT_CreateOverview and schemas
+ Test by hypostase
+ See #3615
+2016-09-09 14:02 Sandro Santilli <strk at kbt.io>
+ * [r15088] postgis/lwgeom_functions_basic.c: Fix lack of support
+ for capitalized-Y in SwapOrdinates
+ Closes #3628
+2016-09-08 16:06 Sandro Santilli <strk at kbt.io>
+ * [r15085] topology/postgis_topology.c: Really fix callback reading
+ Edge data in presence of unexpected NULLs
+2016-09-08 15:52 Sandro Santilli <strk at kbt.io>
+ * [r15083] topology/postgis_topology.c: Fix callback reading Edge
+ data in presence of unexpected NULLs
+2016-09-07 18:21 Sandro Santilli <strk at kbt.io>
+ * [r15080] raster/test/regress/rt_createoverview_expected,
+ regress/run_test.pl: Do not require expecting DISCARD ALL
+ .. actually it may be a good idea to run it always after each
+ test ..
+ * [r15079] regress/run_test.pl: Style only: remove trailing
+ blankspaces
+2016-09-07 18:15 Sandro Santilli <strk at kbt.io>
+ * [r15078] raster/rt_pg/rtpostgis.sql.in,
+ raster/test/regress/rt_createoverview.sql,
+ raster/test/regress/rt_createoverview_expected: Fix schema
+ support in RT_CreateOveriew
+ Patch by hypostase
+ Closes #3615
+2016-09-07 17:45 Sandro Santilli <strk at kbt.io>
+ * [r15077] regress/in_geojson.sql, regress/in_geojson_expected,
+ regress/tickets.sql, regress/tickets_expected: Fix regress tests
+ for builds without JSON support
+2016-09-06 22:44 Daniel Baston <dbaston at gmail.com>
+ * [r15074] postgis/lwgeom_export.c,
+ postgis/lwgeom_in_encoded_polyline.c,
+ regress/in_encodedpolyline.sql,
+ regress/in_encodedpolyline_expected,
+ regress/out_geometry_expected, regress/tickets.sql,
+ regress/tickets_expected: #3627, Encoded polyline functions
+ ignore precision parameter
+2016-09-06 15:16 Regina Obe <lr at pcorp.us>
+ * [r15072] regress/run_test.pl: load_outdb related tests fix for
+ @INC change in perl
+ fix for PostGIS 2.3, patch from Sebastiaan Couwenberg for #3624
+2016-09-06 08:29 Sandro Santilli <strk at kbt.io>
+ * [r15069] NEWS: Formatting (tab to spaces, consistent indenting)
+2016-09-06 06:36 Regina Obe <lr at pcorp.us>
+ * [r15064] Version.config, extensions/upgradeable_versions.mk: Bump
+ trunk to rc1dev
+2016-09-06 04:05 Regina Obe <lr at pcorp.us>
+ * [r15062] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ Version.config, extensions/upgradeable_versions.mk: Prepare for
+ PostGIS 2.3.0beta1 release
2016-09-06 03:49 Regina Obe <lr at pcorp.us>
* [r15061] postgis/Makefile.in: Add postgis_drop_before and
