[postgis-tickets] r15139 - Bring Tuning section up to date, by incorporating some of Mike Toews changes
Regina Obe
lr at pcorp.us
Sun Sep 25 00:32:12 PDT 2016
Author: robe
Date: 2016-09-25 00:32:12 -0700 (Sun, 25 Sep 2016)
New Revision: 15139
trunk/NEWS
trunk/doc/performance_tips.xml
Add mention of configs to enable parallel queries
Get rid of broken link to Kevin Neufeld's old press and replace with PostgreSQL wiki
Closes #3452
Modified: trunk/NEWS
--- trunk/NEWS 2016-09-25 06:10:51 UTC (rev 15138)
+++ trunk/NEWS 2016-09-25 07:32:12 UTC (rev 15139)
@@ -54,6 +54,8 @@
- #3613, Segmentize geography using equal length segments
(Hugo Mercier of Oslandia)
+ * Bug Fixes
+ - #2841, ST_MinimumBoundingCircle not covering original
* Performance Enhancements *
- #75, Enhancement to PIP short circuit (Dan Baston)
@@ -61,6 +63,7 @@
(Dan Baston)
- #3400, Minor optimization of PIP routines (Dan Baston)
- Make adding a line to topology interruptible (Sandro Santilli)
+ - Documentation updates from Mike Toews
PostGIS 2.3.0beta1
2016/09/06
Modified: trunk/doc/performance_tips.xml
--- trunk/doc/performance_tips.xml 2016-09-25 06:10:51 UTC (rev 15138)
+++ trunk/doc/performance_tips.xml 2016-09-25 07:32:12 UTC (rev 15139)
@@ -142,18 +142,22 @@
<sect1 id="database_tuning_configuration">
<title>Tuning your configuration</title>
- <para>These tips are taken from Kevin Neufeld's presentation "Tips for the
- PostGIS Power User" at the FOSS4G 2007 conference. Depending on your
- use of PostGIS (for example, static data and complex analysis vs frequently
- updated data and lots of users) these changes can provide significant
- speedups to your queries.</para>
+ <para>Tuning for PostGIS is much like tuning for any PostgreSQL workload. The only additional note to keep in mind is that
+ geometries and rasters are heavy so memory related optimizations generally have more of an impact on PostGIS than other types of PostgreSQL queries.</para>
- <para>For a more tips (and better formatting), the original presentation
- is at
- <ulink url="http://2007.foss4g.org/presentations/view.php?abstract_id=117">
- http://2007.foss4g.org/presentations/view.php?abstract_id=117</ulink>.
- </para>
+ <para>For general details about optimizing PostgreSQL, refer to <ulink url="https://wiki.postgresql.org/wiki/Tuning_Your_PostgreSQL_Server">Tuning your PostgreSQL Server</ulink>.</para>
+ <para>For PostgreSQL 9.4+ all these can be set at the server level without touching postgresql.conf or postgresql.auto.conf
+ by using the <code>ALTER SYSTEM..</code> command.</para>
+ <programlisting>ALTER SYSTEM SET work_mem = '256MB';
+-- this will force, non-startup configs to take effect for new connections
+SELECT pg_reload_conf();
+-- show current setting value
+-- use SHOW ALL to see all settings
+SHOW work_mem;</programlisting>
+ <para>In addition to these settings, PostGIS also has some custom settings which you can find listed in <xref linkend="PostGIS_GUC" />.</para>
<sect2>
<title>Startup</title>
@@ -162,62 +166,59 @@
</para>
<para>
- <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-wal.html#GUC-CHECKPOINT-SEGMENTS">checkpoint_segments</ulink>
+ <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-query.html#GUC-CONSTRAINT-EXCLUSION">constraint_exclusion</ulink>
</para>
<itemizedlist>
<listitem>
<para>
- Maximum number of log file segments between automatic WAL checkpoints
- (each segment is normally 16MB); default is 3
+ Default: partition
</para>
</listitem>
<listitem>
<para>
- Set to at least 10 or 30 for databases with heavy write activity, or
- more for large database loads. Another article on the topic worth reading <ulink url="http://www.westnet.com/~gsmith/content/postgresql/chkp-bgw-83.htm">Greg Smith: Checkpoint and Background writer</ulink>
+ This is generally used for table partitioning. The default for this is set to "partition" which is ideal for PostgreSQL 8.4 and above since
+ it will force the planner to only analyze tables for constraint consideration if they are in an inherited hierarchy
+ and not pay the planner penalty otherwise.
</para>
</listitem>
- <listitem>
- <para>
- Possibly store the xlog on a separate disk device
- </para>
- </listitem>
</itemizedlist>
<para>
- <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-query.html#GUC-CONSTRAINT-EXCLUSION">constraint_exclusion</ulink>
+ <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-SHARED-BUFFERS">shared_buffers</ulink>
</para>
<itemizedlist>
<listitem>
<para>
- Default: off (prior to PostgreSQL 8.4 and for PostgreSQL 8.4+ is set to partition)
+ Default: ~32MB
</para>
</listitem>
<listitem>
<para>
- This is generally used for table partitioning. If you are running PostgreSQL versions below 8.4, set to "on" to ensure the query planner will optimize as desired.
- As of PostgreSQL 8.4, the default for this is set to "partition" which is ideal for PostgreSQL 8.4 and above since
- it will force the planner to only analyze tables for constraint consideration if they are in an inherited hierarchy
- and not pay the planner penalty otherwise.
+ Set to about 1/3 to 3/4 of available RAM
</para>
</listitem>
</itemizedlist>
- <para>
- <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-SHARED-BUFFERS">shared_buffers</ulink>
+ <para>
+ <ulink url="https://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-MAX-WORKER-PROCESSES">max_worker_processes</ulink>
+ This setting is only available for PostgreSQL 9.4+. For PostgreSQL 9.6+ this setting has additional importance in that it controls the
+ max number of processes you can have for parallel queries.
</para>
<itemizedlist>
<listitem>
<para>
- Default: ~32MB
+ Default: 8
</para>
</listitem>
<listitem>
<para>
- Set to about 1/3 to 3/4 of available RAM
+ Sets the maximum number of background processes that
+ the system can support. This parameter can only be set at
+ server start.
</para>
</listitem>
</itemizedlist>
@@ -233,7 +234,7 @@
<itemizedlist>
<listitem>
<para>
- Default: 1MB
+ Default: 1-4MB
</para>
</listitem>
<listitem>
@@ -250,7 +251,7 @@
<para>
If you have lots of RAM and few developers:
<programlisting>
- SET work_mem TO 1200000;
+ SET work_mem TO '256MB';;
</programlisting>
</para>
</listitem>
@@ -263,7 +264,7 @@
<itemizedlist>
<listitem>
<para>
- Default: 16MB
+ Default: 16-64MB
</para>
</listitem>
<listitem>
@@ -273,15 +274,44 @@
</listitem>
<listitem>
<para>
- Recommend 32MB to 256MB on production servers w/lots of RAM, but depends
+ Recommend 32MB to 1GB on production servers w/lots of RAM, but depends
on the # of concurrent users. If you have lots of RAM and few developers:
<programlisting>
- SET maintainence_work_mem TO 1200000;
+ SET maintenance_work_mem TO '1GB';
</programlisting>
</para>
</listitem>
</itemizedlist>
+ <para>
+ <ulink url="https://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-MAX-PARALLEL-WORKERS-PER-GATHER">max_parallel_workers_per_gather</ulink>
+ This setting is only available for PostgreSQL 9.6+ and will only affect PostGIS 2.3+, since only PostGIS 2.3+ supports parallel queries.
+ If set to higher than 0, then some queries such as those involving relation functions like <code>ST_Intersects</code> can use multiple processes and can run
+ more than twice as fast when doing so. If you have a lot of processors to spare, you should change the value of this to as many processors as you have.
+ Also make sure to bump up <code>max_worker_processes</code> to at least as high as this number.
+ </para>
+ <itemizedlist>
+ <listitem>
+ <para>
+ Default: 0
+ </para>
+ </listitem>
+ <listitem>
+ <para>
+ Sets the maximum number of workers that can be started
+ by a single <varname>Gather</varname> node.
+ Parallel workers are taken from the pool of processes
+ established by <varname>max_worker_processes</varname>.
+ Note that the requested number of workers may not
+ actually be available at run time. If this occurs, the
+ plan will run with fewer workers than expected, which may
+ be inefficient. Setting this value to 0, which is the
+ default, disables parallel query execution.
+ </para>
+ </listitem>
+ </itemizedlist>
</sect2>
</sect1>
