[postgis-tickets] [PostGIS] #2985: server crash when analyzing small tables
trac at osgeo.org
Sun Sep 25 15:08:21 PDT 2016
Reporter: nkiraly | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: fixed | Keywords: analyze server crash freebsd
Comment (by ofca):
Replying to [comment:38 robe]:
> I think I'm missing something. I get this:
> Looking up portsnap.FreeBSD.org mirrors... 7 mirrors found.
> Fetching snapshot tag from your-org.portsnap.freebsd.org... done.
> Fetching snapshot metadata... done.
> Fetching snapshot generated at Thu Sep 22 20:08:34 EDT 2016:
> fetch: http://your-
org.portsnap.freebsd.org/s/0831842c5695b8c81d35df948c917c1e482e189fdb4463687703fc567e5ece22.tgz:
Not Found
There's something wrong with your /etc/portsnap.conf
seems there's
SERVERNAME=your-org.portsnap.FreeBSD.org
instead of normal
SERVERNAME=portsnap.FreeBSD.org
> Any rate I'm not going to have much time to debug this, but I will add
this regress test so that it crashes for anyone packaging who has this
issue when they go to do the make check.
Should your time permit, I'll be happy to help with FreeBSD-specific
questions you may have. I also informed the port maintainer about this
ticket, so lets see how it goes now. Thank you :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2985#comment:41>
