[postgis-tickets] r15147 - bump up to 2.4
Regina Obe lr at pcorp.us
Sun Sep 25 22:40:34 PDT 2016
Author: robe
Date: 2016-09-25 22:40:34 -0700 (Sun, 25 Sep 2016)
New Revision: 15147
   trunk/NEWS
   trunk/Version.config
   trunk/doc/release_notes.xml
   trunk/extensions/upgradeable_versions.mk
bump up to 2.4
Modified: trunk/NEWS
--- trunk/NEWS	2016-09-26 05:34:14 UTC (rev 15146)
+++ trunk/NEWS	2016-09-26 05:40:34 UTC (rev 15147)
@@ -1,5 +1,9 @@
+PostGIS 2.4.0
+2017/xx/xx
 PostGIS 2.3.0
-2016/XX/XX
+2016/09/26
  * Important / Breaking Changes *
@@ -64,7 +68,10 @@
   - #3400, Minor optimization of PIP routines (Dan Baston)
   - Make adding a line to topology interruptible (Sandro Santilli)
   - Documentation updates from Mike Toews
+PostGIS 2.3.0rc1
+2016/09/19
+See PostGIS 2.3.0 section for details
 PostGIS 2.3.0beta1
 2016/09/06
Modified: trunk/Version.config
--- trunk/Version.config	2016-09-26 05:34:14 UTC (rev 15146)
+++ trunk/Version.config	2016-09-26 05:40:34 UTC (rev 15147)
@@ -4,7 +4,7 @@
 # See HOWTO_RELEASE file in SVN for definitions of those three.
 POSTGIS_MAJOR_VERSION=2
-POSTGIS_MINOR_VERSION=3
+POSTGIS_MINOR_VERSION=4
 POSTGIS_MICRO_VERSION=0dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml	2016-09-26 05:34:14 UTC (rev 15146)
+++ trunk/doc/release_notes.xml	2016-09-26 05:40:34 UTC (rev 15147)
@@ -2,7 +2,102 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+     <sect1>
+      <title>Release 2.3.0</title>
+          <para>Release date: 2016/09/26</para>
+          <para>This is a new feature release, with new functions, improved performance, all relevant bug fixes from PostGIS 2.2.3,and other goodies.</para>
+        <simplesect>
+          <title>Important / Breaking Changes</title>
+            <para>#3466, Casting from box3d to geometry now returns a 3D
+                     geometry (Julien Rouhaud of Dalibo)</para>
+            <para>#3396, ST_EstimatedExtent, throw WARNING instead of ERROR
+                     (Regina Obe)</para>
+        </simplesect>
+        <simplesect>
+            <title>New Features</title>
+              <para>Add support for custom TOC in postgis_restore.pl
+                (Christoph Moench-Tegeder)</para>
+              <para>Add support for negative indexing in ST_PointN and ST_SetPoint
+                (Rémi Cura)</para>
+              <para>Add parameters for geography ST_Buffer (Thomas Bonfort)</para>
+              <para>TopoGeom_addElement, TopoGeom_remElement (Sandro Santilli)</para>
+              <para>populate_topology_layer (Sandro Santilli)</para>
+              <para>#454,  ST_WrapX and lwgeom_wrapx (Sandro Santilli)</para>
+              <para>#1758, ST_Normalize (Sandro Santilli)</para>
+              <para>#2236, shp2pgsql -d now emits "DROP TABLE IF EXISTS"</para>
+              <para>#2259, ST_VoronoiPolygons and ST_VoronoiLines (Dan Baston)</para>
+              <para>#2841 and #2996, ST_MinimumBoundingRadius and new ST_MinimumBoundingCircle
+                       implementation using Welzl's algorithm (Dan Baston)</para>
+              <para>#2991, Enable ST_Transform to use PROJ.4 text (Mike Toews)</para>
+              <para>#3059, Allow passing per-dimension parameters in ST_Expand (Dan Baston)</para>
+              <para>#3339, ST_GeneratePoints (Paul Ramsey)</para>
+              <para>#3362, ST_ClusterDBSCAN (Dan Baston)</para>
+              <para>#3364, ST_GeometricMedian (Dan Baston)</para>
+              <para>#3391, Add table inheritance support in ST_EstimatedExtent
+                       (Alessandro Pasotti)</para>
+              <para>#3424, ST_MinimumClearance (Dan Baston)</para>
+              <para>#3428, ST_Points (Dan Baston)</para>
+              <para>#3465, ST_ClusterKMeans (Paul Ramsey)</para>
+              <para>#3469, ST_MakeLine with MULTIPOINTs (Paul Norman)</para>
+              <para>#3549, Support PgSQL 9.6 parallel query mode, as far as possible
+                       (Paul Ramsey, Regina Obe)</para>
+              <para>#3557, Geometry function costs based on query stats (Paul Norman)</para>
+              <para>#3591, Add support for BRIN indexes. PostgreSQL 9.4+ required.
+                       (Giuseppe Broccolo of 2nd Quadrant, Julien Rouhaud
+                        and Ronan Dunklau of Dalibo)</para>
+              <para>#3496, Make postgis non-relocateable for extension install,
+                       schema qualify calls in functions (Regina Obe)
+                       Should resolve once and for all for extensions #3494, #3486, #3076</para>
+              <para>#3547, Update tiger geocoder to support TIGER 2016
+                       and to support both http and ftp.</para>
+              <para>#3613, Segmentize geography using equal length segments
+                       (Hugo Mercier of Oslandia)</para>
+        </simplesect>
+        <simplesect>
+            <title>Bug Fixes</title>
+               <para>All relevant bug fixes from PostGIS 2.2.3</para>
+               <para>#2841, ST_MinimumBoundingCircle not covering original</para>
+               <para>#3604, pgcommon/Makefile.in orders CFLAGS incorrectly leading to
+                       wrong liblwgeom.h (Greg Troxel)</para>
+        </simplesect>
+        <simplesect>
+            <title>Performance Enhancements</title>
+              <para>#75, Enhancement to PIP short circuit (Dan Baston)</para>
+              <para>#3383, Avoid deserializing small geometries during index operations
+                       (Dan Baston)</para>
+              <para>#3400, Minor optimization of PIP routines (Dan Baston)</para>
+              <para>Make adding a line to topology interruptible (Sandro Santilli)</para>
+              <para>Documentation updates from Mike Toews</para>
+      </simplesect>
+   </sect1>
+   <sect1>
+      <title>Release 2.2.2</title>
+        <para>Release date: 2016/03/22</para>
+        <para>This is a bug fix and performance improvement release.</para>
+  		  <simplesect>
+          <para>#3463, Fix crash on face-collapsing edge change</para>
+          <para>#3422, Improve ST_Split robustness on standard precision double systems (arm64, ppc64el, s390c, powerpc, ...)</para>
+          <para>#3427, Update spatial_ref_sys to EPSG version 8.8</para>
+          <para>#3433, ST_ClusterIntersecting incorrect for MultiPoints</para>
+          <para>#3435, ST_AsX3D fix rendering of concave geometries</para>
+          <para>#3436, memory handling mistake in ptarray_clone_deep</para>
+          <para>#3437, ST_Intersects incorrect for MultiPoints</para>
+          <para>#3461, ST_GeomFromKML crashes Postgres when there are innerBoundaryIs and no outerBoundaryIs</para>
+          <para>#3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms</para>
+          <para>#3460, ST_ClusterWithin 'Tolerance not defined' error after upgrade</para>
+          <para>#3490, Raster data restore issues, materialized views. Scripts postgis_proc_set_search_path.sql, rtpostgis_proc_set_search_path.sql refer to http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore</para>
+          <para>#3426, failing POINT EMPTY tests on fun architectures</para>
+  		  </simplesect>
+    </sect1>
      <sect1>
 	<title>Release 2.2.1</title>
 		  <para>Release date: 2016/01/06</para>
Modified: trunk/extensions/upgradeable_versions.mk
--- trunk/extensions/upgradeable_versions.mk	2016-09-26 05:34:14 UTC (rev 15146)
+++ trunk/extensions/upgradeable_versions.mk	2016-09-26 05:40:34 UTC (rev 15147)
@@ -20,8 +20,8 @@
 	2.2.0 \
 	2.2.1 \
 	2.2.2 \
-	2.3.0beta1 \
-	2.3.0rc1
+	2.2.3 \
+	2.3.0
 # This is to avoid forcing "check-installed-upgrades" as a default
 # rule, see https://trac.osgeo.org/postgis/ticket/3420
