[postgis-tickets] r15149 - PostGIS 2.3.0 release announcement
Regina Obe
lr at pcorp.us
Mon Sep 26 13:22:03 PDT 2016
Author: robe
Date: 2016-09-26 13:22:03 -0700 (Mon, 26 Sep 2016)
New Revision: 15149
Added:
web/_content/posts/2016/09-26_postgis-2.3.0.html
web/_content/config.yml
web/_content/pages/documentation.html
web/_content/pages/source.html
Modified: web/_content/config.yml
--- web/_content/config.yml 2016-09-26 05:45:26 UTC (rev 15148)
+++ web/_content/config.yml 2016-09-26 20:22:03 UTC (rev 15149)
@@ -9,8 +9,8 @@
date_format: Y/m/d
postgis:
- version: 2.2.2
- trunk_version: 2.3.0dev
+ version: 2.3.0
+ trunk_version: 2.4.0dev
release_docs: http://download.osgeo.org/postgis/docs
release_source: http://download.osgeo.org/postgis/source
dev_download: http://postgis.net/stuff
Modified: web/_content/pages/documentation.html
--- web/_content/pages/documentation.html 2016-09-26 05:45:26 UTC (rev 15148)
+++ web/_content/pages/documentation.html 2016-09-26 20:22:03 UTC (rev 15149)
@@ -13,6 +13,7 @@
## Stable Branch User Documentation
This documentation is for the released branches and will contain corrections and errata as they are available
+* PostGIS 2.3 ([HTML]({{ site.root }}docs/manual-2.3)) ([PDF]({{ site.root }}stuff/postgis-2.3.pdf)) ([EPUB]({{ site.root }}stuff/postgis-2.3.epub))
* PostGIS 2.2 ([HTML]({{ site.root }}docs/manual-2.2)) ([PDF]({{ site.root }}stuff/postgis-2.2.pdf)) ([EPUB]({{ site.root }}stuff/postgis-2.2.epub))
* PostGIS 2.1 ([HTML]({{ site.root }}docs/manual-2.1)) ([PDF]({{ site.root }}stuff/postgis-2.1.pdf)) ([EPUB]({{ site.root }}stuff/postgis-2.1.epub))
* PostGIS 2.0 ([HTML]({{ site.root }}docs/manual-2.0)) ([PDF en]({{ site.root }}stuff/postgis-2.0.pdf))
Modified: web/_content/pages/source.html
--- web/_content/pages/source.html 2016-09-26 05:45:26 UTC (rev 15148)
+++ web/_content/pages/source.html 2016-09-26 20:22:03 UTC (rev 15149)
@@ -7,7 +7,7 @@
# Source Code
The latest source code and companion user doc releases are:
-* [postgis-2.3.0rc1.tar.gz]({{postgis.release_source}}/postgis-2.3.0rc1.tar.gz) [pdf]({{postgis.release_docs}}/postgis-2.3.0rc1.pdf) [html]({{postgis.release_docs}}/doc-html-2.3.0rc1.tar.gz) ([Release Notes](http://svn.osgeo.org/postgis/tags/2.3.0rc1/NEWS))
+* [postgis-2.3.0.tar.gz]({{postgis.release_source}}/postgis-2.3.0.tar.gz) [pdf]({{postgis.release_docs}}/postgis-2.3.0.pdf) [html]({{postgis.release_docs}}/doc-html-2.3.0.tar.gz) ([Release Notes](http://svn.osgeo.org/postgis/tags/2.3.0/NEWS))
* [postgis-{{ postgis.version }}.tar.gz]({{postgis.release_source}}/postgis-{{ postgis.version }}.tar.gz) [pdf]({{postgis.release_docs}}/postgis-{{ postgis.version }}.pdf) [html]({{postgis.release_docs}}/doc-html-{{ postgis.version }}.tar.gz)
([Release Notes](http://svn.osgeo.org/postgis/tags/{{ postgis.version }}/NEWS))
* [postgis-2.1.8.tar.gz]({{postgis.release_source}}/postgis-2.1.8.tar.gz) [pdf]({{postgis.release_docs}}/postgis-2.1.8.pdf) [html]({{postgis.release_docs}}/doc-html-2.1.8.tar.gz) ([Release Notes](http://svn.osgeo.org/postgis/tags/2.1.8/NEWS))
@@ -22,6 +22,7 @@
## Latest stable branch snapshots:
+* [postgis-2.3.1dev.tar.gz]({{postgis.dev_download}}/postgis-2.3.1dev.tar.gz)
* [postgis-2.2.3dev.tar.gz]({{postgis.dev_download}}/postgis-2.2.3dev.tar.gz)
* [postgis-2.1.9dev.tar.gz]({{postgis.dev_download}}/postgis-2.1.9dev.tar.gz)
* [postgis-2.0.8SVN.tar.gz]({{postgis.dev_download}}/postgis-2.0.8SVN.tar.gz)
Added: web/_content/posts/2016/09-26_postgis-2.3.0.html
--- web/_content/posts/2016/09-26_postgis-2.3.0.html (rev 0)
+++ web/_content/posts/2016/09-26_postgis-2.3.0.html 2016-09-26 20:22:03 UTC (rev 15149)
@@ -0,0 +1,105 @@
+title: PostGIS 2.3.0 Released
+layout: post
+category: news
+tags: [release, 2.3, 2.3.0]
+author: Regina Obe
+thumbnail: postgis.png
+The PostGIS development team is pleased to announce the release of PostGIS 2.3.0.
+This is the first version to utilize the parallel support functionality introduced in PostgreSQL 9.6.
+As such, if you are using PostgreSQL 9.6, we strongly encourage you to use this version.
+Parallel support will make many queries using PostGIS relationship operators and functions faster.
+In order to take advantage of parallel query support, make sure to set max_parallel_workers_per_gather to something greater than 0
+as noted in [`max_parallel_workers_per_gather` PostgreSQL runtime configs](https://www.postgresql.org/docs/9.6/static/runtime-config-resource.html#GUC-MAX-PARALLEL-WORKERS-PER-GATHER)
+Best served with [PostgreSQL 9.6+] which is due out this week and [pgRouting 2.3.0](https://lists.osgeo.org/pipermail/pgrouting-users/2016-September/002287.html)
+which also just got released.
+Packages from maintainers will be out in the coming days and weeks.
+* [Download]({{postgis.release_source}}/postgis-2.3.0.tar.gz)
+* [html doc download]({{postgis.release_docs}}/doc-html-2.3.0.tar.gz)
+* [pdf doc download]({{postgis.release_docs}}/postgis-2.3.0.pdf)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.3.0/ChangeLog)
+If you are a Mac user using newer XCode 8, you might run into some compilation issues
+as a result of recent changes in XCode. Refer to [https://trac.osgeo.org/postgis/ticket/3643](https://trac.osgeo.org/postgis/ticket/3643)
+for a patch you can use.
+Please [reporting bugs](http://postgis.net/support/) that you find in this release.
+ **Important / Breaking Changes / Bug Fixes**
+ * All relevant fixes coming in PostGIS 2.2.3 are in this release
+ * 3466, Casting from box3d to geometry now returns a 3D
+ geometry (Julien Rouhaud of Dalibo)
+ * 3604, pgcommon/Makefile.in orders
+ CFLAGS incorrectly leading to wrong liblwgeom.h
+ (Greg Troxel)
+ * 3396, ST_EstimatedExtent, now throws WARNING instead of ERROR
+ (Regina Obe)
+ **New Features and Performance Enhancements**
+ * Add support for custom TOC in postgis\_restore.pl
+ (Christoph Moench-Tegeder)
+ * Add support for negative indexing in ST\_PointN and ST\_SetPoint
+ (Rémi Cura)
+ * Add parameters for geography ST\_Buffer (Thomas Bonfort)
+ * TopoGeom\_addElement, TopoGeom\_remElement (Sandro Santilli)
+ * populate\_topology\_layer (Sandro Santilli)
+ * 454, ST\_WrapX and lwgeom\_wrapx (Sandro Santilli)
+ * 1758, ST\_Normalize (Sandro Santilli)
+ * 2236, shp2pgsql -d now emits "DROP TABLE IF EXISTS"
+ * 2259, ST\_VoronoiPolygons and ST\_VoronoiLines (Dan Baston)
+ * 2841 and #2996, ST\_MinimumBoundingRadius and new ST\_MinimumBoundingCircle
+ implementation using Welzl's algorithm (Dan Baston)
+ * 2991, Enable ST\_Transform to use PROJ.4 text (Mike Toews)
+ * 3059, Allow passing per-dimension parameters in ST\_Expand (Dan Baston)
+ * 3339, ST\_GeneratePoints (Paul Ramsey)
+ * 3362, ST\_ClusterDBSCAN (Dan Baston)
+ * 3364, ST\_GeometricMedian (Dan Baston)
+ * 3391, Add table inheritance support in ST\_EstimatedExtent
+ (Alessandro Pasotti)
+ * 3424, ST\_MinimumClearance (Dan Baston)
+ * 3428, ST\_Points (Dan Baston)
+ * 3465, ST\_ClusterKMeans (Paul Ramsey)
+ * 3469, ST\_MakeLine with MULTIPOINTs (Paul Norman)
+ * 3549, Support PgSQL 9.6 parallel query mode, as far as possible
+ (Paul Ramsey, Regina Obe)
+ * 3557, Geometry function costs based on query stats (Paul Norman)
+ * 3591, Add support for BRIN indexes. PostgreSQL 9.4+ required.
+ (Giuseppe Broccolo of 2nd Quadrant, Julien Rouhaud
+ and Ronan Dunklau of Dalibo)
+ * 3496, Make postgis non-relocateable for extension install,
+ schema qualify calls in functions (Regina Obe)
+ Should resolve once and for all for extensions #3494, #3486, #3076
+ * 3547, Update tiger geocoder to support TIGER 2016
+ and to support both http and ftp.
+ * 3613, Segmentize geography using equal length segments
+ (Hugo Mercier of Oslandia)
+ **Bug Fixes**
+ * 2841, ST_MinimumBoundingCircle not covering original
+ * Performance Enhancements *
+ * 75, Enhancement to PIP short circuit (Dan Baston)
+ * 3383, Avoid deserializing small geometries during index operations
+ (Dan Baston)
+ * 3400, Minor optimization of PIP routines (Dan Baston)
+ * Make adding a line to topology interruptible (Sandro Santilli)
+ * Documentation updates from Mike Toews
+See the full list of changes in the [news file](http://svn.osgeo.org/postgis/tags/2.3.0/NEWS) and please [report bugs](https://trac.osgeo.org/postgis) that you find in the release.
+Binary packages will appear in [repositories](http://postgis.net/install) over the coming weeks as packagers roll out builds.
+View all [closed tickets for 2.3.0][1].
+ [1]:http://trac.osgeo.org/postgis/query?status=closed&groupdesc=1&group=priority&milestone=PostGIS+2.3.0&order=priority
